need help with installing clutch disc
Old Jun 6, 2008 | 01:24 AM
madvette74's Avatar
madvette74
Default need help with installing clutch disc
hello..
it's been awhile, last year I had my motor built, and I am getting ready
to install it, except I cant remember what side faces the flywheel..
can you tell me by these picutres what side faces the flywheel. it's a centerforce...
also can you tell me the tq amount for the pressure plate and flywheel?
do I need you use locktight on the bolts?
[IMG][/IMG]
[IMG][/IMG]
Old Jun 6, 2008 | 07:46 AM
Durango_Boy's Avatar
Durango_Boy
The bottom picture is the face that goes in.
Old Jun 6, 2008 | 07:53 AM
...Roger...'s Avatar
...Roger...
Can a disc really be installed backwards?I've heard people talking about this lately.The springs usually hit the flywheel.I've never tried actually installing the disc backwards and putting the bolts in the pressure plate-are the bolts long enough?
On your 2nd pic the disc is backwards-try putting the disc against the flywheel and now rotate the disc you should feel the springs contacting the flywheel-now flip it over and you will feel the disc material touching the flywheel.
To need help with installing clutch disc
