Power window clunking noise
Old Jun 7, 2008 | 07:40 AM
Black_80's Avatar
Black_80
Default Power window clunking noise
My power windows on my 1980 go up and down but the driver side window makes a clunking noise as it moves. It still moves pretty fast. Last year I had a problem with the door intermittently not unlocking. When I was in there fixing that I tried to clean and lube the window tracks but with no improvement. Any suggestions?
Old Jun 7, 2008 | 08:06 AM
mrvette's Avatar
mrvette
Yup, the window is hanging up on something in there, tough to say WHAT though......BTDT years ago, and it varies with the cars....
could be a bolt too long, just snags part of the mechanism
Old Jun 7, 2008 | 08:38 AM
c3corvettes's Avatar
c3corvettes
I have the same issue with my '80. I also hear a clunking noise on the driver side window as it moves up or down. It too moves pretty fast. The power door lock on the driver side and passenger side also has an intermmitent problem of not unlocking.
Old Jun 7, 2008 | 10:40 AM
Black_80's Avatar
Black_80
I also had the problem with the power door locks. The rubber boot on the soleniod was long since gone. Cleaning and lubing that helped a lot.
Old Jun 7, 2008 | 12:37 PM
...Roger...'s Avatar
...Roger...
What works for me most of the time is greasing the hook on the coiled spring but you have to pry it back and get the grease between the hook in the spring and the stud the spring hooks on.
Old Jun 8, 2008 | 06:42 PM
Black_80's Avatar
Black_80
Thanks, DWncchs. This sounds like something worth trying. It'll be a lot of fun reaching through the hole to do it but I could see this making the kind of clunking noise I have!
To Power window clunking noise
