Vacuum Reservoir
Old Jul 26, 2008 | 12:44 AM
jim2527's Avatar
jim2527
JB Weld will crack. It failed as soon as I tested my tank. I ended up using a flexible 2-part epoxy from West Marine.
The local radiator joint told me to take a walk.
Old Jul 26, 2008 | 01:58 AM
GunPowder's Avatar
GunPowder
Willcox has a used correct 69 vacuum tank. But is is not a bargain
Old Jul 26, 2008 | 12:16 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Yeah, I know it a not cheap. There just are not any good cans out there anymore. http://willcoxcorvette.com/product_i...ducts_id=24815
Old Jul 26, 2008 | 07:06 PM
c31980's Avatar
c31980
Originally Posted by 7T1vette
A vacuum reservoir is necessary. It doesn't have to be the factory unit, however. The reservoir [and back-flow valve] maintain the level of vacuum required to operate headlights and, especially, wipers even when you go WOT (no vacuum when you 'floor' it). You probably don't need the same size can as factory provides, but you still need one.
i see ,, thanks for the info
