Is this block scrap?
Old Jun 9, 2008 | 06:43 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Default Is this block scrap?
I finally got around to pulling the crank and getting the block ready to go to the shop, but after inspecting the bottom of the bores, cylinder 7 is looking mighty skimpy, and thats through my untrained eye. Its roughly 0.08" thick at the base. What do you guys make of this cylinder? (Please ignore my flat tire)
Old Jun 9, 2008 | 07:06 PM
Gordonm's Avatar
Gordonm
Has it ever been bored before. Measure the bore of it right now. If it is only 4.000 or even 4.030 you are OK. If it is 4.040 or bigger I would pass on the block and find a better one. Don't worry what the bottom looks like.
Old Jun 9, 2008 | 08:23 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
The piston never reaches there anyway so as stated check where it is important.
Old Jun 9, 2008 | 08:28 PM
LeMans Pete
Took measurements at the top and bottom of the bore (couldn't get the middle of the bore due to my dial bore's limitations) and both verified that the block was never bored: 4.001 at bottom, 3.997 at top.
Why is the block notched at the bottom of the bore?
So you guys would say as long as the bore is fine, regardless of how thick the cylinder wall is at the bottom, it would be fine?
Old Jun 9, 2008 | 08:34 PM
400hp427vette
St. Jude Donor '09
The piston never has and friction with that part of the block. I have seen that part of the blocked notched out for rod bolt clearance on a friends race engine. it doesn't look the same as yours But If it works for high horsepower, That should be OK.
Old Jun 9, 2008 | 08:39 PM
LeMans Pete
Ya, I mean you can clearly see where the bottom ring stops. I'm more concerned if I wanted to bore this out to 4.030 if I may be losing alot of cylinder wall.
Old Jun 9, 2008 | 08:58 PM
400hp427vette
St. Jude Donor '09
Take it to a machine shop you trust, Since they are doing to machine work I'm sure they wouldn't touch one they see might fail.
Old Jun 9, 2008 | 09:48 PM
Gordonm's Avatar
Gordonm
With those measurements it looks like it has never been bored before. You should be fine with a .030 overbore. The machine shop will be able to determine if it is good or not.
Old Jun 9, 2008 | 10:32 PM
L88Plus's Avatar
L88Plus
Keep in mind that a .030 overbore will only take .015 off of each side of the cylinder. That's 1.5 tenths of a tenth of an inch. I don't think I've ever dealt with a 350 that wouldn't take at least a .030 overbore, most will take .040 and a few are fine at .060 over.
Old Jun 9, 2008 | 11:06 PM
TimAT's Avatar
TimAT
Get the block bored and sleeves put in all 8 holes. Then bore the sleeves .125 over. Be Happy
4.125 bore + 3.48 stroke = 371 cubic inches
Old Jun 9, 2008 | 11:10 PM
cosmicvette's Avatar
cosmicvette
Is this the original motor? If so why worry about going so big with the overbore you really don't get that much extra capacity by over-boring the cylinders, just see what the machine shop recommends as the minimum to get good cylinders.
If you want more capacity a stroker crank is going to yield a much bigger capacity increase.
Old Jun 9, 2008 | 11:29 PM
LeMans Pete
The initial concern is if the cylinder wall had been unevenly worn. It is the original motor. I'll talk over the options with the machine shop. I don't know why I would sleeve all cylinders when they are all fine.
Thanks for the help guys, on with the build!
Old Jun 10, 2008 | 12:20 AM
offroadtoyota's Avatar
offroadtoyota
It costs the exact same amount to go 10 over or 30 over. Get the extra 5 CI. Are you really going to do this twice from high mileage wear?
Old Jun 10, 2008 | 07:16 AM
L88Plus's Avatar
L88Plus
It actually costs less to go .010 over - that's just a hone, most shops can't bore .010 because of tool drift. Those are hard pistons to find, too. .020 is more common, most manufacturers start at .030
Old Jun 10, 2008 | 08:10 AM
LeMans Pete
I don't know what you mean about doing it twice from high mileage wear. You can still see the original honing marks.
Old Jun 10, 2008 | 08:22 AM
bashcraft's Avatar
bashcraft
In order to install sleeves thick enough to overbore .125, you would need to cut the old cylinder completely away. You would essentially have wet sleeves and it would leave no support for the deck. In other words, it won't work.
Old Jun 10, 2008 | 08:32 AM
BLOCKMAN's Avatar
BLOCKMAN
We build a lot of circle track and street and strip performance engines and deal with probably 200 blocks a year and we have seen the bottom of cylinders like that before and its never been a problem so far.
And putting in sleeves for a .125 over bore not going to happen as the wrist pin side of the cylinder are between .070 to .160 thick which you would be boring into the water jackets, and there would be alot of cracking around the bolt holes when the heads are torqued down as we have seen this problem with the 400 blocks when sleeving them, The other problem is at the bottom of the cylinders as the webbing would get very thin and in a performance application there would be cracking from the step down through the main webbing.
If your building a performance engine here have it sonic tested for cylinder wall thickness and squared and decked so the cylinders are a true 45 degrees and 90 degrees to the crank and have it plate honed for good ring seal.
Good luck with your build Carl
Old Jun 10, 2008 | 09:45 AM
hugie82's Avatar
hugie82
If it was my block I wouldnt worry about that but if it were cracking or chipped I would take a grinder to it so nothing breaks off and falls into the pan IMHO
Old Jun 10, 2008 | 09:54 AM
V-Twin's Avatar
V-Twin
that's normal, that is from where the core molds meet
To Is this block scrap?
