TH400 won't shift?
Old Jun 9, 2008 | 06:52 PM
glassman74's Avatar
glassman74
Default TH400 won't shift?
I down shifted first from dr. to 2nd, then 2nd to low at about 20 mph,
and came to complete stop. Put it back up in dr. when I took off, it
would not shift at all. It just stayed in low. Luckly I was only a
mile from home. Check oil and it is full with no oder.
What the H#ll could be the problem??? All help wanted.
By the way, I was coming home from my first car show sence I
got the car back on the road. (500+ cars at it in Ontario,Ca.)
Thanks in advance. glassman74
Old Jun 9, 2008 | 07:22 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
First thing to look at is the vacuum modulator. Make sure it's connected. If it came undone on a downshift, the very next thing I would replace would be the pass. side motor mount.
Old Jun 9, 2008 | 07:23 PM
...Roger...'s Avatar
...Roger...
Will it go into park? If it wont it might be the cable.Otherwise make sure you have vacuum at the modulator.
Old Jun 10, 2008 | 04:21 PM
glassman74's Avatar
glassman74
Found problem. Broken vac hose on trans.
Thanks glassman74
To TH400 won't shift?
