Roller cam maintenance?
Old Jun 11, 2008 | 07:30 PM
76projectstingray's Avatar
76projectstingray
Default Roller cam maintenance?
I am thinking of putting a roller cam in my L 82 or buy a crate motor with a roller cam and have seen a few qoutes from people saying you have to deal with the maintenance issues? Do you have to adjust the rockers more often with a roller setup then a flat tappet?
Old Jun 11, 2008 | 07:56 PM
chris75stingray's Avatar
chris75stingray
as long as you stay with hydraulic lifters there should be no difference. but if you get solid roller lifters, that's when they require a little more attention
Old Jun 11, 2008 | 08:12 PM
weimer20's Avatar
weimer20
I haven't run solid rollers but a friend put a set in his 454 and he reports that he was able to essentially set it and forget it. His are holding their adjustment quite well.
Old Jun 11, 2008 | 09:47 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
If you go solid roller, key to lash staying put after run in is a good interface between high quality screw-in rocker studs and the adjusters (such as ARP's & Posi-Lock's). Then, unless something starts going wrong you really shouldn't have to crack the valve covers open all that often except to monitor things periodically.
DO NOT restrict top end oiling on the street and make sure to use lifters that sufficiently oil the roller bearing (such as CompCams' Endure-X w/pressurized EDM oiling). Just so it doesn't go unsaid, you'll need a button since roller grinds have no taper to check cam walk and, as with any engine, be certain to get the cam/dizzy gear combo right.
Hope that helps.
Old Jun 11, 2008 | 10:04 PM
gingerbreadman1977's Avatar
gingerbreadman1977
all skunk works info is good and thats all the main points to consider. i run crane roller cam with hydraulic lifters. set your posi loc pressures down when u install the cam and forget about it for years.
Old Jun 11, 2008 | 10:44 PM
hjgator's Avatar
hjgator
I have a ZZ4 in mine, is that a solid or hydraulic lifter cam?
Old Jun 11, 2008 | 11:30 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
I am running a Lunati solid roller right now, the only issue I see is the bronze gears do not last long with high spring tension. There is another option out there but I don't remember the name of the gear. As has been stated before, once the lifters are adjusted they should stay there for a long while.
Neal
Old Jun 12, 2008 | 01:43 AM
gingerbreadman1977
hydraulic
Old Jun 12, 2008 | 06:49 AM
Fonz69's Avatar
Fonz69
using a 540 solid roller and have checked them allott and they never seem to move
Old Jun 12, 2008 | 07:58 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
A lot has to do with how crazy the lobe is. *Street* solid rollers will run a long time with no issues. Small blocks do better than big blocks due to valve/pushrod angles and pressures required for the heavier valves.
As mentioned a good valvetrain is essential. Mine needs very little maintenance/checking. I do it before I go racing..but otherwise I don't worry about it much. But you DO have to listen for any new noises indicating a lifter is dying. They don't heal themselves and if you catch them quick, no big damage is done.
Always spend the $50 for the pressed on iron dist gear so you can run stock gears and not have to mess with bronze or fancy stuff.
Make sure to use a bronze tip pushrod for fuel pump if applicable.
DON'T use the austempered iron cam cores..get a real billet one.
And as mentioned, no oil restrictors and get good lifters.
JIM
Old Jun 12, 2008 | 10:35 AM
vett us all's Avatar
vett us all
I Installed Stud Girdles Doug Herbert Solid Roller 1.6 Harland Sharp Rockers. No Problems. Used Factory Finned Covers To
Old Jun 12, 2008 | 05:44 PM
76projectstingray
Thanks for all of the replies, I seems like there are no issues as long as they are set up right. Thanks Again!
Old Jun 12, 2008 | 07:06 PM
68/70Vette's Avatar
68/70Vette
Last month's Hot Rod magazine had one of a series of articles about a BB 540 build up. The had their engine running on hydraulic rollers with about 200 (?) lb of valve spring tension. Next they ran the engine with a solid roller cam. Because of the high rpm potential of the solid roller, they went to 500 lb of valve spring tension.
So, I think the consideration here is, in addition to the question of durability of a roller cam - hydraulic versus solid, is what is your valve spring pressure? A solid roller with 200 lb springs is, say, not going to have any longevity issues, but if you install 500 lb springs, the cam's livetime can probably be expected to significantly diminish.
Old Jun 12, 2008 | 07:28 PM
boat196's Avatar
boat196
Are those spring pressures on the seat. I had a BBC that ran 360# @ 2.100 on the seat . I never had a wear issue on the cam, but the springs had a short life.
Old Jun 12, 2008 | 07:42 PM
Glensgages's Avatar
Glensgages
I've never run a roller-lifter cam of any-type, and I have a question that I don't believe I've ever seen asked or answered:
what is the expected life-span of the roller-lifter itself.....
do the bearings fail, and if-so, how-long can you realistically expect them to last?
Thanks-in-advance!
Old Jun 12, 2008 | 08:16 PM
Durango_Boy's Avatar
Durango_Boy
Thanks-in-advance!
I can't tell you the overall length, but I have seen a GM roller 350 with near 300K miles and everything was stock original. Same for my Mopar roller engines...the lifters all seem to be just fine.
I think how they are treated and maintained and how aggressive the engine is built has a lot more to do with the life of the roller lifter than just miles or time.
Old Jun 12, 2008 | 11:05 PM
1981Z06Vette's Avatar
1981Z06Vette
In a stock application, with regular oil changes, a couple hundred thousand miles isn't unheard of.
Old Jun 13, 2008 | 04:19 AM
gingerbreadman1977
longer than a flat tappet cams and the like....if only they werent so bloody expensive to buy initially.
Old Jun 13, 2008 | 05:48 AM
Belgian1979vette's Avatar
Belgian1979vette
Key is to keep things lubricated as you would normally do with any other type of valvetrain.
To Roller cam maintenance?
