Diff update
Old Jun 12, 2008 | 12:13 AM
Simmo's Avatar
Simmo
Default Diff update
Ive got the rear out to fix leaks. I plan on getting a shop to fit a new bearing kit and new carbon fibre clutch plates. Anything else I should order?
One of the side yolks has a stripped thread and the previous owner fitted a longer bolt with a nut. Zip advertise an uprated side yolk that is drop forged, heat treated from "aircraft quality steel". Are these worth getting? I cant afford a Toms rear.
Car will be street only driven and have a mild 540 manual.
Old Jun 12, 2008 | 01:03 AM
avner's Avatar
avner
PM gtr1999 he will help/advice you.
Old Jun 12, 2008 | 02:48 AM
vett us all's Avatar
vett us all
Stock Clutch Plates You Are Not Going To Fly With A Mild 540 But You Might Soar. Remember Kiss! Peace To All You Rat Lovers.
Old Jun 12, 2008 | 08:00 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Maybe get the Tom's yokes and spider gears to go with it. BIG improvement over much of the cheaper imported junk.
JIM
Old Jun 12, 2008 | 12:24 PM
GTR1999's Avatar
GTR1999
would not use fiber clutches
Old Jun 12, 2008 | 10:56 PM
Simmo's Avatar
Simmo
Why not the fibre clutches?
How much are the Toms yolks and spider gears, does he have a website or email address. Phoning (in the middle of the night) is too hard from Australia.
Old Jun 12, 2008 | 11:49 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I think I'd get the heavy duty cover. Maybe it's my dumb luck, but I have two BB 73 Vettes and both had cracked rear covers. One was a small crack only noticable from the inside. Van Steel or VB&P has it,..about $90.
Old Jun 13, 2008 | 12:17 AM
stinger12's Avatar
stinger12
They won't last too long. They will smudge right in your fingers. The ones you want to use are the steel GM clutches (not the snowflake ones).
Old Jun 13, 2008 | 08:42 AM
Mark Snyder's Avatar
Mark Snyder
GM steel plate kit 64-80 483722 includes both the discs and the guides. Soak them over night in fluid with GM additive.
Also get the two side plates 3869320 and four springs 3890899
GM at least until 1990 or so also offerred a heavy duty set of spider gears for the diff. They were listed as "heavy duty, L88/ZL1" in the GM power book at that time. I do not have that now but someone else might. I have the posi above and the spider gear kit in a factory posi case I deburred and had shot peened (local machine shop that also shot peens connecting rods). I have it behind a stout big block with stick shift since 1992 and I have never had it apart. Also running 275 wide Gatorback tires.
To Diff update
