For shop manual deficient owners
For those who don't own one. This is the best money spent on any type of upgrade or anything. It may not increase Hp but may bring it back to where it should be. It probably will reduce the labor and broken parts. It is ammunition for when you go to a garage, you know how the system works even if the mechanic doesn't.
These things not only tell you how to do something but explain the operation of the system. It tells what tools you need and sometimes pictures of them.
Each chapter begins with the operation of the system it is addressing. The starting system explains the whole mess so you know whats going on.
Some systems include a trouble shooting chart so you can pin point the possible parts without blindly swapping parts in the hopes of a cure.
It has the wiring diagrams which on a Corvette is important, IE. the wiper motor has only 1 positive wire and all the control wires are grounds. If you haven't discovered that there is a seperate ground wiring system You will very soon. most grounds are wired in, like on the dash.
It is a little course in auto mechanics by itself.
The body manual takes up where the shop manual stops. All that under the surface how does it come apart stuff. the cosmetics. And the body wiring.
If your not sure you need to spend the money you can get one for free from the public library ( you have to return it). They can get it from their main branch. Even if you don't buy one you should get one to read through.
Re: For shop manual deficient owners (gdh)
GDS
Try http://www.Helm's.com . They have an 800 number on the site. If they don't have your book in stock they can tell you who does.
Re: For shop manual deficient owners (Techno)
I work on a lot of different cars, and can't really justify spending the money on a whole shop manual for a lot of them, so I go to my local library and use theirs. Most of the time I look up what I want, and copy the pages (it's like 10 cents a page) that way I don't get their books all greasy at home. If you are working on something, go to you library and get the info on it first. They have a wealth of information. I think our library has 4 different kinds of shop manuals, and it's not a large library.
Couldn't of said it better, Techno :cheers: something to mention also...This is the same "Service Manual" that the Automotive Dealers use in they're shops :yesnod: it's a step by step process to check systems or repair them.
