Volumetric Efficiency
Old Jun 15, 2008 | 11:55 AM
Rab16's Avatar
Rab16
Default Volumetric Efficiency
I've been playing around with a dyno program and noticed that along with giving the power and torque at given RPMs it also gives you the "volumetric efficiency", which it explained was the percent of air/fuel that is able to enter the cylinder before the intake valve closes. Using different cam profiles and valve sizes I've been able to get just about the same power curve regardless of the efficiency. So my question is, do I want high efficiency or low efficiency? At first I thought the closer I got to 100% the better because I would get more power out of every stroke, but then I messed with the cam specs more and got my efficiency up to about 120% and realized that this would cause close to no vacuum at the intake. I also realized that if I can get the power I want with very LOW efficiency I would burn less gas per cycle and get better mileage. So do I want high efficiency or low?
Old Jun 15, 2008 | 12:23 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
Thats hard to answer, you want the closest to 100 percent while keeping it streetable. Also the only real way to go over 100 percent is the use of a turbo or supercharger.
Old Jun 15, 2008 | 12:34 PM
V-Twin's Avatar
V-Twin
Not true, you can get over 100% w/ NA engines also, the trick is in good scavenging of the exhaust and valve timing.
Old Jun 15, 2008 | 01:41 PM
gkull's Avatar
gkull
Combined with tuned ports that actually ram air in after piston at BDC.
This is only achieved over a small rpm range
Old Jun 15, 2008 | 03:17 PM
Rab16's Avatar
Rab16
So what kind of negative effects will I get with low vol. eff.?
Old Jun 15, 2008 | 04:43 PM
gkull's Avatar
gkull
poor performance, bad gas mileage. The most efficient motors are probably between 1.0 and 1.3 hp per ci
Old Jun 15, 2008 | 04:59 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Desktop dyno isn't exact. You will get better performance and mileage @ close to 100% VE. My build is 100% VE from 4500 to 6000 RPM according to Desktop Dyno...............which isn't exact.
Old Jun 15, 2008 | 06:26 PM
Rab16's Avatar
Rab16
Here's what my dyno's telling me, sounds too good to be true but I'm looking at almost 500 ft/lbs just off idle. Cam would have to be a custom grind since I'm pretty sure nobody makes anything like this. I'll post the specs on that as soon as I get them printed.
RPM HP. TQ. Eff.
2000 178 468 94.5
2500 235 493 96.3
3000 281 492 96.8
3500 328 492 98.5
4000 370 486 99.4
4500 404 472 98.4
5000 421 442 95.9
5500 418 399 91.9
6000 396 347 86.0
6500 352 284 79.0
7000 300 225 72.6
Old Jun 15, 2008 | 06:31 PM
gkull's Avatar
gkull
How many ci do you have to get that near 500? It takes a very highly tuned motor to approach 1.3 foot pounds per ci
Old Jun 15, 2008 | 06:40 PM
Rab16's Avatar
Rab16
383, it's the setup in my profile except for the cam.
Old Jun 15, 2008 | 08:58 PM
Rab16's Avatar
Rab16
Here's the cam specs, I'll admit I just messed with the numbers to get the efficiency up. I don't really know what they mean in terms of idle quality and vacuum.
Camshaft type- High Performance Street
Lifter- Roller
Cam Specs @- Seat To Seat
Int. Lift @ Valve- .500
Exh. Lift @ Valve- .500
Lobe Center- 114.9
Valve Overlap- 34.0
Int. Duration- 240
Exh. Duration- 287.5
Timing @ Adv. 15.0
IVO (BTDC)- 0.0
EVO (BBDC)- 73.5
ICA (ATDC)- 120.0
IVO- 15.0
EVO- 88.5
ICA- 105.0
IVC- 45.0
EVC- 19.0
ECA- 124.8
Old Jun 16, 2008 | 08:32 AM
gkull's Avatar
gkull
only use existing numbers from cam cards.
DD2000 is way off of reality because it rewards massive exhaust valve timing. So use real life cam card numbers and the .050 numbers increase the accuracy
Old Jun 16, 2008 | 12:36 PM
Rab16's Avatar
Rab16
Great that's what I was afraid of, so you're saying this cam cannot exist?
Old Jun 16, 2008 | 01:34 PM
gkull's Avatar
gkull
Well 240 degrees seat to seat is a rediculessly low duration number. Also cam manufactures tend to keep spit duration cams to within 12 or 14 degrees.
When you order a custom cam each manufacturer only has a list of so many lobe designs and machinable blanks of certain Lobe Center angles.
So you look for the type of lobe that you want H-flat, Solid Flat, h-roller or S-roller. Then you choose the intake lobe duration and exhaust lobe duration and then tell them what LSA you want
I have free flowing exhaust so on my 383 solid roller I went with 236/242 @ .050 on comp cams XR profile at 112 LSA
Old Jun 16, 2008 | 11:34 PM
hobby0002000's Avatar
hobby0002000
Go to the AFR website and click on small block chevy heads, then check out cylinder head dyno results and cylinder head magazine articles, this may help out with motor combinations if its something your not real sure of.
To Volumetric Efficiency
