'82 Transmission
Old Jun 15, 2008 | 03:20 PM
Wino33's Avatar
Wino33
3rd Gear
Default '82 Transmission
Just acquired my first corvette, an '82. Real clean, runs well. My only concern is that the transmission feels like it hesitates in the middle gears. It accelerates from a stop really well, but after cruising at 20-30mph, it hesitates when I gas it. But it doesn't feel like it is slipping. It almost seems to shift to the wrong gear when I'm just coasting. Is this typical for the '82 c3 or should it respond more quickly? Could it be time to rebuild the tranny?
Old Jun 15, 2008 | 03:54 PM
Durango_Boy's Avatar
Durango_Boy
With the engine hot and running, check the fluid level in the transmission. It sounds like it might be a bit low.
Old Jun 15, 2008 | 10:17 PM
82crossfirevette's Avatar
82crossfirevette
That's the overdrive kicking in. I believe it's the Shift Points but I could be wrong. There was a discussion, not too long ago, on how to adjust it. Hopefully some of the trans guru's will chime in.
Old Jun 16, 2008 | 11:29 AM
Blue Seducer's Avatar
Blue Seducer
To '82 Transmission
