Tri-power 1/4 mile question
Old Jun 15, 2008 | 11:26 PM
loflite's Avatar
loflite
Default Tri-power 1/4 mile question
Ran my '69 427-400hp for the first time in the quarter mile. Car has original carbs and ignition. Car ran fine and accelerated great until 4500 RPM. AT 4500 RPM it would start to stutter and would not increase in RPM until I up shifted. The secondaries opened up at about 3500 RPM. One run it back fired at about 4500 RPM along with the stutter. Any ideas? Is it the timing or carburetion? Thanks.
Old Jun 16, 2008 | 12:16 AM
GDaina's Avatar
GDaina
Plugs? Inline carb fiilter? Wires? I assume all are new. I would replace the carb filters with a filter on the line. The little brass filters are restrictive
Old Jun 16, 2008 | 12:19 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Could be lots of things. Plugs in good shape etc? I'd disconnect secondary carbs and see if it does same thing. Idea it to reduce fuel pump needs and see if it cleans up only feeding 2bbls. If it doesn't, we're likely back to ignition unless pump is really bad or is pulling air from somewhere.
Any idea on engine condition? A 427/400 has a mild cam...so it doesn't take much valvespring...but if one or more are real weak it could do this.
JIM
Old Jun 16, 2008 | 02:59 AM
KevinK's Avatar
KevinK
I had the same problem with my car, though I am not running anything close to the same set up as you, just a stock L-48. It turned out just to be a bad fuel pump. Replaced it, and now she wants to roar right into the red line, if I let her.
To Tri-power 1/4 mile question
