Adjustable controller for Spall fans Dewitts kits
Old Jun 16, 2008 | 01:18 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Adjustable controller for Spall fans Dewitts kits
I am thinking about getting the Dewitts rad and fan kit but I would like to be able to adjust when the fans come on and shut off. Anyone have a controller that is adjustable for the Spal fans ?
Old Jun 16, 2008 | 02:41 PM
Gordonm's Avatar
Gordonm
I have had the PWM controller for a couple of years now. It ramps up the fan speed so they do not run at full speed until needed. It starts out at 50% and goes up as the temp goes up. You can set your own on/off settings. One word of caution they cannot be set to close. Say on at 190 and off at 180. If I remember it has to be a 15 to 20 degree difference. I had a little trouble at first because I was trying to set them to close. Some have had problems with this unit mine has been trouble free for a few years now.
Old Jun 16, 2008 | 03:17 PM
MotorHead's Avatar
MotorHead
They quit selling the PWM because of all the problems now the sell the old system which is preset at 195 on and 175 off
Old Jun 16, 2008 | 04:12 PM
Gordonm's Avatar
Gordonm
I just installed a set of Dual Spals with the 195/175 this past weekend on another members car. The fans run all the time once the car is warm. It runs at about 160 to 170 but the fans still run. I think we got a bad switch. A new one is coming this week.
I talked to Tom about the PWM and he said for some reason the Vettes have a problem with the PWM. Other cars not so much. I keep my fingers crossed that mine keeps working.
Old Jun 16, 2008 | 04:25 PM
gkull's Avatar
gkull
I've got the system, but you have to be able to read a temp gauge
Twin 50 amp lighted toggle switches. If and When the gauge gets to 180 I strain against my 5 point belts to reach the the dash to hit one of the toggle switches. If and when it gets to 210 I strain to reach switch number 2.
For awhile I had one come on with ignition, but I couldn't ever get the motor to heat up. I have not turned on the second fan yet and it was 90 over the weekend. So I'm thinking about putting in the next smaller reducer washer. I think that I have the one inch and need a 7/8th to get some heat in it.
Old Jun 16, 2008 | 06:19 PM
Overlord's Avatar
Overlord
From: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
Here's one I was looking at with programmable temps. Haven't used it, not even sure if it's suitable, but maybe worth a look.
http://www.dakotadigital.com/index.c...prod/prd43.htm
Old Jun 16, 2008 | 09:34 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
This is a common request so I thought I would comment on it. I'm sure everyone has heard of the KISS rule? It really applies with fan controls. The programable, solid state controllers are really over kill for such a simple fuction. The idea sounds great at first but you really have to program the on and off about 20 degrees different for these to function correctly. You also should maintain a 180 stat to insure that you burn off any condensation in the crankcase. So if you set them to shut off at 180, and turn on at 200, why is that any different than the fixed 175/195 that we offer? It's not!
Another reason I like the simple relay and switch system is that they work almost all the time, but when they don't, trouble shooting is very simple. That's not the case with the electronics. The electronic senders are an analog device, which means you check them with an ohm meter. The controller are solid state devices and you can't check them, so when something goes wrong you fix them by replacing parts. The relay and switch system is so simple. If something goes wrong, you can touch the switch wire to some ground and if the fans come on, then the switch is bad. If they don't, then the relay is bad. Real reliable and real simple.
Old Jun 16, 2008 | 10:05 PM
Gordonm's Avatar
Gordonm
And there you have it. This is what Tom told me last year also. If my controller goes bad I'm going back to a simple system. In the future if/when I go to fuel injection I'll have the computer turn the fans on and off. I'd stick with the simple system if I were to do it over again.
Old Jun 16, 2008 | 10:58 PM
MotorHead's Avatar
MotorHead
I would actually like it to be 5 degrees cooler, on at 190 and off at 170
Old Jun 16, 2008 | 11:55 PM
gingerbreadman1977's Avatar
gingerbreadman1977
i have been through 2 different types of auto fan switches , and my mate another brand. i found them to be unreliable to the point that occassionally they didnt even come on at the set temp. i have gone to the good old trusty set up of an on/off switch low on my dash where the over-ride lights pop up button is. now when my car hits 190 i just flick it on . once i start cruising i turn it off. its not a daily driver and im the only one who drives it so thats the way i like it.i have fairly good cooling so i only have to turn it on when im at the lights for a long period.most lights im going again before the temp gets up.its not for everyone but if you like it simple and fail safe i recommend it.
Old Jun 17, 2008 | 06:43 AM
73jst4fun's Avatar
73jst4fun
Thought I'd chime in here, Gordon and I installed my fan kit this past weekend, as he mentioned the fans don't shut off. We have checked everything, using an IR gun and the gauge , have a 160 high flow thermosat, bled the radiator in case there was an air pocket, still the fans don't shut off, I called Tom DeWitt but he was out of the office and his person was very helpfull and is sending me a new sensor, hope this is the problem and Tom can add some feedback to this problem on this post.....Thanks
Old Jun 17, 2008 | 06:08 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Again, trouble shooting is simple. If the fans run continously, try disconnecting the wire the goes to the switch. If that doesn't stop the fans, then it can't be the switch. Also, remember you have to drop to 175 in order for the fans to reset and shut off.
Old Jun 17, 2008 | 07:08 PM
Older Than Dirt's Avatar
Older Than Dirt
I wired my dual spals independent of each other. One fan is controlled by a sensor located in the head, the other fan is controlled by a sensor located in the intake. If one fan and/or sensor was to malfunction, the other one would continue to operate.
Old Jun 17, 2008 | 07:42 PM
fugawi's Avatar
fugawi
try this one www.dccontrol.com works slick as goose grease. my temp comes to 182 and stays put .
Old Jun 17, 2008 | 07:55 PM
PhotoVette1's Avatar
PhotoVette1
A perfect controller.
Old Jun 17, 2008 | 08:17 PM
Gordonm's Avatar
Gordonm
To bad the link does not work like goose poop.
bozzman3's Avatar
bozzman3
I have this as well and works flawless!
To Adjustable controller for Spall fans Dewitts kits
Old Jun 17, 2008 | 09:33 PM
73jst4fun's Avatar
73jst4fun
Thanks Tom for the reply, my fans don't run when the car is started, they start when the temperature gets to about 160, then the fans start and will not shut off, Gordon and I have checked everything that's why we think the only thing it could possibly be is the sensor....anything else we could of possibly missed, it's a simple system to trouble shoot....Thanks again
Old Jun 17, 2008 | 10:15 PM
MotorHead's Avatar
MotorHead
Is this the link for the controllers, if so which one do you guys have ?
http://www.dccontrol.com/fancontrol.htm
Old Jun 18, 2008 | 03:59 PM
73jst4fun's Avatar
73jst4fun
ttt...
