valve noise?
Old Jun 16, 2008 | 04:30 PM
thunderlips's Avatar
thunderlips
Default valve noise?
After my 454 warms up, it starts to make a clacketing (real word?) noise, but only after it warms up. A freind said i needed to adjust the valve of something. So far i have done all work to my car and i am a determined learner. How do i go about adjusting the valves? where do i find the specs for a custom built 454 and isn't a torque wrench needed? Please talk to me like a child when explaining because i know nothing! Thank you very much.
Old Jun 16, 2008 | 08:14 PM
SH-60B's Avatar
SH-60B
Are you saying the motor has been modified? Adjusting the valves is pretty easy on a hydraulic cam, different for a solid cam. Even the most basic manual, like a Haynes, will explain the proceedure better than I could with pics to boot. If you really want to learn more about motors consider getting a subscription to Hot Rod or a similar publication.
Old Jun 16, 2008 | 09:08 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
If you need the rocker arms / lifters / valves adjusted .... this will get rid of the clickity clackety! Zero lash + half a turn.
Best method for the job! You can do it!
https://www.corvetteforum.com/techti...=116&TopicID=3
Old Jun 16, 2008 | 09:10 PM
vett us all's Avatar
vett us all
Thunderlips I Suggest You Ask Your Friend That Suggested You Adjust The Valves Teach You How It's Done. What Are Friends For? Peace Out.
To valve noise?
