1977 Fusebox
Old Jun 17, 2008 | 12:25 PM
Blues77's Avatar
Blues77
Default 1977 Fusebox
Can someone tell me the correct amps for the individual fuses. Or a pic would be great. THanks!
Old Jun 17, 2008 | 01:46 PM
bmotojoe's Avatar
bmotojoe
Straight out of the 1977 Electrical Troubleshooting Manual
Old Sep 4, 2023 | 09:48 PM
Besc31977's Avatar
Besc31977
1st Gear
I’m sorry if I’m hijacking the thread, but can someone please tell me exactly what the name of the plug that goes into the BAT connector in the center of the fusebox? All I have are IGN and ACC. Thank you!
Old Sep 4, 2023 | 10:11 PM
Bikespace's Avatar
Bikespace
I think they are called fuse taps. You can buy a lifetime supply here:
https://americanautowire.com/product...s&_ss=e&_v=1.0
Welcome to the Forum! Please start a new thread to introduce us to your car.
Old Sep 4, 2023 | 10:47 PM
bmotojoe's Avatar
bmotojoe
Hey Bike, those are ATO fuse taps...
Those are for the newer fuse boxes 79 on.
The only fuse tap for the glass style fuses I have found is for the ACCY socket Delphi #6288101
The BAT socket connector is Delphi #6288103, IGN connector is Delphi #6288105
The ACCY socket is also HOT at all times.
If you have Power Windows the ACCY will be used as it feeds the common contacts of the PW relay.
OP could use a standard 1/4" female crimp connector if needed, it will not lock into the cavity as good as the correct connector....
To 1977 Fusebox
