Harmonic Balancer Question
Old Jun 17, 2008 | 08:38 PM
DJordan442's Avatar
DJordan442
Default Harmonic Balancer Question
I ordered a new balancer from Summit for my 427 and the catalogue said that 8 inch diameter is OEM so that is what i ordered. Today i removed the old balancer (didnt check diameter) and started putting the new one on and i could tell that it was not going to clear the timing indicator tab that is welded to the timing cover. I stopped and looked at the old balancer and knew right away that it was a 7 inch diameter balancer What gives? What came OEM on a 427/400 with a/c? thanks
Old Jun 17, 2008 | 09:23 PM
LT-1 kid's Avatar
LT-1 kid
i have the same motor 69 and it is a 7" balancer, greg
Old Jun 18, 2008 | 11:21 AM
Jeff_Keryk's Avatar
Jeff_Keryk
The 7 inch is correct. I replaced mine (68 427) with an 8 inch; broke off the timing tab and used a bolt on tab. I am soooo sorry I did this. I now had Damper Doc rebuild my 7 inch and will replace the timing cover and damper. I think I paid about $70 and got timing marks scribed onto the damper. In my opinion, this is the only way to go.
Old Jun 21, 2008 | 12:40 AM
DJordan442's Avatar
DJordan442
guys - thanks for the feedback
To Harmonic Balancer Question
