1969 Windshield Date Code
Old Jun 18, 2008 | 08:20 PM
Steve 427's Avatar
Steve 427
Default 1969 Windshield Date Code
Guys,
Where is the date code located on the windshield and how does it usually read? Thanks
Old Jun 18, 2008 | 09:31 PM
GPGG70's Avatar
GPGG70
Originally Posted by Steve 427
Guys,
Look at the lower passenger side corner by the window pillar.
LOF was the maker of the glass back then not sure now.
It should read something like Shaded Soft Ray Safety plate, ASI, CV, or
XV, or YV.
The two cap letters on the right side of the LOF are the date codes from the lof company.
I dont have my book to tell you what the dates are but you might be able to fined them if you google LOF and or know someone with a NCRS judging book.
The date code needs to preceed the build date of your car as much as up to 6 months.
I have a early 70 coupe and my front windshield is CV.
I'm looking at a very early vert and the front windshield has LG and if I remember right that was a date for 1976 or 86 or 96. So the lof number told me the window had been replaced at some point in the cars history.
Old Jun 18, 2008 | 11:26 PM
GPGG70's Avatar
GPGG70
XV, or YV.
Failed to mention that the LOF stands for Libby Owens Ford.
The two letter date code are for the month and year.
For example C=January and V= 1970.
The the month & the year I've placed next to the letter may not be the correct dates cause like I said I dont have my book to confirm but hopefully you get the idea.
Hope this helps.
Old Jun 19, 2008 | 12:03 AM
Steve 427's Avatar
Steve 427
Hope this helps.
Very cool!!! Thanks for all the info. Found mine it is a code IV which is June 1969 and my car was built at the end of July 69. Seems correct.
Old Jun 19, 2008 | 12:13 AM
Carl Granquist's Avatar
Carl Granquist
Default I'd like to know too
Build date for my '71 is April 13th, and I believe it's the original glass. I'm also curious how to read this information.
Old Jun 19, 2008 | 01:12 AM
Steve 427's Avatar
Steve 427
[QUOTE=Carl Granquist;1565959328]Build date for my '71 is April 13th, and I believe it's the original glass. I'm also curious how to read this information.[/QUOTE
Your code looks like "IN" which translates to I=June and N=1971. To be original the glass date should preceed your vehicle build date.
After looking at it again if what I think is a "I" might be a faded "L" then it would be March and would make it correct.
Old Jun 19, 2008 | 01:35 AM
Peterbuilt's Avatar
Peterbuilt
Default Best to keep original!
You guys are smart to try to keep everything original. My 74 was not matching #'s when I got it and one day a low flying bird hit the windshield and broke it. I ended up calling State Farm and there guy put in a "Pilkinton" windshield. It works fine, with no leaks, but you are right try to get a correct replacement any time you can. It will be worth more if you ever do sell it. PG.
Old Jun 19, 2008 | 01:56 AM
GPGG70's Avatar
GPGG70
Not sure about the 71's but your heading in the right direction.
I think it's neat to find all of the numbers on these cars.
It took a while to find the date codes for the 70s but here they are.
Keep in mind that you will find 69 glass well into the 70 production and you'll find 70 glass well into the 71 production and so on.
I cant tell you why the codes were coded with the two letters as being the month & year and who knows maybe GM doesnt know why either, it's the way LOF did it and its pretty easy once a person has the dang letters for the month / year.
V=1969 production, & T=1970 production.
N=january, X=February, L=March, G=April, J=May, I=June, U=July, T=August, A=September, Y=October, C=November, & V=December.
So like on my car CV=November/1969.
Hope this helps.
Old Jun 19, 2008 | 09:14 AM
Sully1882's Avatar
Sully1882
does anyone have the info for windshields on a 72?
thanks
sully
Old Jun 19, 2008 | 10:45 AM
BKarol's Avatar
BKarol
try this
http://www.corvette-world.com/corvet...te%20Codes.php
Old Jun 19, 2008 | 12:04 PM
GPGG70's Avatar
GPGG70
Originally Posted by karol
Thank for the link. From time to time I've been needing to look up other years date codes on certain items and this is a good link.
Thanks, again.
To 1969 Windshield Date Code
