What FI is BesT??????????
Old Jun 19, 2008 | 11:49 AM
lethalassault's Avatar
lethalassault
Default What FI is BesT??????????
I really need to know what FI system is best and will look the nicest in my 1973 vert. I really like that Holloy FI it really is a work of art!! Will this fit under a factory hood?
What FI system will fit under my factory hood?
Did anyone install the Holloy in their c3? I was thinking about going with a mass flow FI system.
So which FI is the best for this zz383???
http://massfloefi.com/
Edelbrock Performer RPM Pro-Flo2
http://store.summitracing.com/partde...5&autoview=sku
ACCEL DFI Street-Ram Fuel Injection Systems for Small Block Chevy
Holley Commander 950
Holley Stealth Ram MPFI
Thanks!
Old Jun 19, 2008 | 12:46 PM
Roughrider's Avatar
Roughrider
I have the Edelbrock Pro-Flow RPM installed in one of my cars (not a Vette...an Avanti). It's excellent...smooth and powerful system. The only negative I can say is the electric fuel pump is on the loud side, but I've been told most similar systems all have the same characteristic.
Whether it will clear a stock Corvette hood I don't know, but I did have to have my chosen air cleaner modified for clearance under the sloping hood. I had other options for an air cleaner system, but I was able to have what I wanted.
I have no experience with the other brand EFI's you mentioned, but I'm sure they're all fine systems. Each likely has strong points over the others. Since you have a stroker, I guessing it probably has a pretty healthy camshaft. You should get the cam specs and make sure each EFI is compatible...not all are compatible with extreme cam profiles.
Old Jun 19, 2008 | 01:23 PM
Gordonm's Avatar
Gordonm
This is a post that is a little old but has some good info on FI. I like the Mass Flo system.
http://forums.corvetteforum.com/show...fuel+injection
Old Jun 19, 2008 | 07:42 PM
Mark L. Warner's Avatar
Mark L. Warner
I like this one:
Old Jun 19, 2008 | 08:33 PM
roscobbc's Avatar
roscobbc
Originally Posted by Mark L. Warner
I like this one:
Beautiful
Old Jun 19, 2008 | 09:31 PM
CorvetteDave01's Avatar
CorvetteDave01
I had the Edelbrock proflo efi setup fitting under my '76 L82 hood with a drop base moroso air cleaner (the older Proflo setups). The new ones look to be the same intake. Intake was 5.75" front and rear, TB was 2.25", and I had a .5" aircleaner spacer on it. Air cleaner barely cleared the bottom of the hood on the front.
FAST also makes a complete kit now and it looks like they use the Edelbrock 'EFI' intake from what I can see. Not sure how much it is though.
I currently have the FAST xfi computer with a solid roller 427sb and a ridiculous amount of money messing with intake setups, finally went with a custom Motown. Most setups will probably work fine on your 383, but I would read the below article.
Her is a great link comparing intake setups for efi.
http://www.compcams.com/Community/Ar...?ID=1737510521
Attached is a pic of my new intake setup that should be done next week.
Old Jun 19, 2008 | 09:43 PM
CorvetteDave01
Here is a current C4 section link
http://forums.corvetteforum.com/show....php?t=2052204
Old Jun 19, 2008 | 10:59 PM
gyopp's Avatar
gyopp
I am not sure which Holley system you are asking about anyone installing but I have a modified stealth ram intake with an Accel computer. It definately will not fit under a stock hood. It barely fits under a L88 hood The link Dave posted above shows this setup supporting a healthy 383 in thier test. Mine has been opened up through the entire runner, port matched to felpro 1206 intake gaskets, and knife edged at the dividers. I wish that I had flow numbers to see what improvement this made.
Old Jun 19, 2008 | 11:29 PM
Ron R's Avatar
Ron R
Can you use your existing intake with any of these setups?
Old Jun 20, 2008 | 07:10 AM
MN80Vette's Avatar
MN80Vette
You can with the Holley Commander 950. That's what I am going to use to replace my Holley carb on my GM Vortec intake.
Old Jun 20, 2008 | 07:14 AM
CorvetteDave01
Nice setup Gene, didn't realize you had a stealth ram setup and I also wouldn't have thought it would fit under even an L88 hood.
Old Jun 20, 2008 | 08:05 AM
TPIShark's Avatar
TPIShark
My Stealth Ram fits under the factory hood on my '76. (Without the insulation, and removed one insulation "post". It's tight, but it clears. The more I look at that setup though, appears to be an 80-82, based on the hood latches, which would be a smaller hood. Very nice though!
Old Jun 20, 2008 | 08:20 AM
gyopp's Avatar
gyopp
Actually, this is a 77. I don't know what is different but I don't see how this would fit under the stock hood. I only have about a half inch of clearance above the throttle body and it sits under the raised part of the hood.
Old Jun 20, 2008 | 08:36 AM
gyopp's Avatar
gyopp
Here is a pic of the manifold on the engine without the upper plenum. This is the best pic I have to give you some perspective of how tall this manifold is.
Old Jun 20, 2008 | 08:39 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
If I were to go FI I would get the stealth ram and the hood.
www.stealthram.com
Old Jun 20, 2008 | 10:20 AM
Ron R's Avatar
Ron R
Interesting ... are there jets available for motors that make over 540 HP? No matter what I do with the floaters in the Holley I still shut down on a hard turn every once in a while. Never had that problem with the Quadrajet on the stock motor, but I'm not going to get the same HP if I put the Qjet on my 383. I'd like to do more autocross but the possibility of the carb causing me to shut down is preventing it. I've adjusted the thing like a million times, seems like its either too much or not enough. For the 950 I saw some injectors that said 450 HP, but the only higher ones I found were for 650 HP 540's. I'm already running an electric fuel pump, I'd love an EFI setup where I could just pull the carb, drop it in, and start her up.
Old Jun 20, 2008 | 10:23 AM
lethalassault
Well I guess the Holly Stealth Ram is out because I do not want to change the hood.
Will the ACCEL FI system fit under a stock hood?
I really want a pretty FI system but is these above 2 wont fit under the stock hood I will go with the massflo to be on the safe side.
What do you guys think?
I am about to start ordering parts next Thursday!!!
Julius
To What FI is BesT??????????
Old Jun 20, 2008 | 04:14 PM
CorvetteDave01
I haven't heard much about the massflo other than it isn't as perfect as they say it is in adjusting to any motor and you do have to do some programing with it. Do they sell a kit? I would really look at any kit's intake manifold, throttle body and injector configuration before you buy it as those can be seriously limiting factors if you ever upgrade. Also, how versitile is the ecu that comes with the kit, can it use low impedance injectors for example? High impedance injectors stop at about 44-48 lb I think and then you are stuck. Does the kit have an adjustable fp regulator?
If your going with a 383 that Holley stealth ram seems like a good setup if you can get it to fit, I think they look cool as heck too. Ported, they are supposed to flow enough for 600 hp (300 cfm+) so that would be good for a future upgrade motor more than likely.
The only limiting factor to the Edelbrock proflo setup (old one) that I had was that you couldn't program it with a computer to adjust for major engine upgrades, but the new one can.
Old Jun 20, 2008 | 09:04 PM
MN80Vette's Avatar
MN80Vette
The Holley Commander 950-24S is recommended for engines rated up to 525 HP and the 950-21S is for engines up to 600 HP. I think the injectors flow about 85-90 pph at 90%. You probably won't just be able to drop it in and start her up without programming it first. You'll need a laptop computer for the 950. The software comes with a couple different maps for high HP engines. You just load a map and fine tune it as needed and save it. Guys typically develop their own library of maps for different driving plans.
Old Jun 20, 2008 | 10:55 PM
CorvetteDave01
Let me say from my recent experience that the preprogrammed maps are almost worthless unless your motor is nearly identical in every way to the motor the map was programmed for. Cubic inches, compressoin, cam, injectors, intake, heads, everything. One change and it starts throwing things off, I am guessing.
For example, there were two different 427 ci maps with my FAST setup and I tried both and neither one did anything but sputter, barely run at 2500 rpm, foul the plugs and foul the O2 sensor. I'm sure someone experienced in tuning could start from such a map, but me...no way. I trailored it to a guy that spent a couple hours getting it running right.
Now that I keep changing things, I keep going back and spending more and more money. I really need to start learning to tune this thing...
