Calibrating a new Tach .... (board)
Old Jun 19, 2008 | 04:40 PM
81_vette!'s Avatar
81_vette!
Default Calibrating a new Tach .... (board)
I recently installed a new tach board and filter.
My tach is certainly all over the place.
It is reading about 2K above where it should be, but at idle it is lower than it should be. When I shut the car off it's any body's guess where the needle will end at.
I did the resetting procedure of turning the ignition to the on position, then hand-setting the needle to 0.
Any idea what the deal is?
Old Jun 19, 2008 | 05:40 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Maybe this can help:
http://www.corvettemagazine.com/2005.../tach-lead.asp
Old Jun 19, 2008 | 07:04 PM
billsfan's Avatar
billsfan
Some replacement boards are not calibrated well. Mine reads about 1000-1500 rpm high, checked against my digital tach. Some guys have sent the board back 3 or 4 times until they got one that was correct. There is no adjustment possible, except for the needle.
To Calibrating a new Tach .... (board)
