rear driver wheel tilted, why?
Old Jun 21, 2008 | 11:58 PM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
Default rear driver wheel tilted, why?
my driver side rear wheel is canted all kinds of wierd... the bottom is further out, and the top is further in than on any other tire on the car.. the other 3 appear pretty straight to the naked eye. my question is what could cause this? bad wheel bearing? is there camber/caster in the read that i am unaware of? it drives alright, other than the steering feeling loose, but it is old, so i expected that. no rattles or wierd bouncing. car is a '79 auto.
Old Jun 22, 2008 | 12:47 AM
Peterbuilt's Avatar
Peterbuilt
Default Rear camber out of wack.
You'll have to look under the rear of the car and see if the camber adjustment bolt is loose, it's under the differential. Or the bushings are worn out and may have to be replaced. PG
Old Jun 22, 2008 | 05:48 AM
BenUK's Avatar
BenUK
or perhaps the differential yoke is worn, allowing the driveshaft to slide further inboard than it should.
Jack the car up and waggle the wheel top to bottom. Check where you have play. If you don't have any then perhaps it just needs an alignment.
Old Jun 22, 2008 | 08:14 AM
V77Vette's Avatar
V77Vette
or could be bearing, how many mile you got on it?
Old Jun 22, 2008 | 10:46 AM
joshtried's Avatar
joshtried
so there is a camber on the rear?? wierd.. and cool i guess. ill jack it up in a bit to see if it wiggles.. can someone tell me where this camber bolt is?
Old Jun 22, 2008 | 11:01 AM
Iskenderian's Avatar
Iskenderian
The camber adjustment bolt is an ob-long shaped adjuster located on the inboard end of the strut rod. (under the diff) If it comes loose, the lets the strut rod move outward (moving the bottom of the wheel outward) I ditched the stock strut rods and went with aftermarket (easier to adjust). BTW...you live about 10 minutes from me, (I'm in Carthage)
_Isky_
Old Jun 22, 2008 | 11:02 AM
L82shark's Avatar
L82shark
St. Jude Donor '08
Look for the strut rod that runs from under the diff to the shock mount on each tire assembly. The bolts that hold it are somewhat adjustable and will allow you adjust the tire. I have the adjustable strut rods on mine and its somewhat easier to adjust than the factory set up. As said earlier make sure all your bushings are in good shape, if they're not the wheel will move.
Old Jun 22, 2008 | 12:34 PM
Averystingray75's Avatar
Averystingray75
my rear drivers tire is the same way has brand new suspension (i didnt put it in, previos owner) but i checked it and he had receits i have been trying to figure out what wrong with the the camber looks good, shocks are new, the leafs are new...
jposhjtired-Let me know if you get it fixed/what has wrong
Old Jun 22, 2008 | 03:02 PM
joshtried's Avatar
joshtried
Fixed it!! it was the camber bolt. i looked at the other side, and the washer was more outside than inside.. well, driver side was reversed.. so i loosened the nut, turned the bolt from the front of the car until the bolt was midline and the washer was toward the outside. the bolt should be on the bottom inside, on both sides.. at least for mine. my boots and what not are a little worn, but in this case, it was just needing to be repositioned. hope this helps avery (compared one side to the other and then make them match, in the simplest of terms)
Old Jun 22, 2008 | 03:15 PM
Averystingray75
Yeah wow thats exactly the same problem mine was! just cralled under it and checked. if it didnt start to rain i'd fix it! thanks-
Old Jun 22, 2008 | 03:42 PM
joshtried's Avatar
joshtried
well, im glad i could help. good luck fixing it later on! its always great when you learn how to fix something!
To rear driver wheel tilted, why?
