Valves problem
Old Jun 22, 2008 | 03:37 AM
heng1's Avatar
heng1
Default Valves problem
Hi there
I have some strange problem with the valves, I spent the last 3 weekends trying to resolve it and I just don't know what it is anymore. I put a new cam in and new headers on, in the shop they set it more or less ok. However the engine just doesn't run smooth. RPM are not stable, vacuum advance also goes weird. so I started fiddling with the valve settings, vacuum is higher, runs a bit smoother but now some valve is "slapping" ( real loud tapping noise..). I thought a hydraulic lifter was broken so I replaced all of them, no difference, I set the valves like said in the book, tighten the nut until the pushrods don't turn anymore and then add 1 turn. Then the engine does not run smooth, and 1 valve slaps. when I set the valves just so the pushrods don't turn anymore and I don't add the 1 turn the engine runs quite good, but the one valve still slaps. Any help is appreciated, I am loosing my nerve here..
Old Jun 22, 2008 | 04:18 AM
chevr0letman's Avatar
chevr0letman
There is a way to see if it is indeed your valve adjustment or something else, but it is messy.
Get your car warmed up, shut it off and remove valve covers. Turn the car back on and find out which valve is making the noise then loosen the rocker arm nut until your engine stumbles and tighten it slowly 3/4 turn. If the noise persists throughout the process, then you can rule out valve adjustment and start looking elsewhere.
Be advised that this is a messy process and oil will be flying everywhere so be prepared to work as quickly as possible and have all your tools ready to go.
Old Jun 22, 2008 | 05:35 AM
heng1's Avatar
heng1
I think this is the last possibility, I know what side it is on but not which valve. should I tighten or loosen? why does it make noise anyway? what else could it be? it worked fine before, maybe a bit low on compression but no noise.
Old Jun 22, 2008 | 06:07 AM
RunningMan373's Avatar
RunningMan373
there are clip on oil sling guides you can get that will deflect the oil back into the head, not a perfect choice, but it will help alot.
Old Jun 22, 2008 | 07:31 AM
tommyleea's Avatar
tommyleea
If you tightened the nut until the pushrod wouldn't turn, and then went another turn, you don't have any cushion in your lifters anymore. You are bottomed out. Tighten the nut until you feel some resistance while spininng the pushrod between thumb and finger, then go another 3/4 to 1 turn. This will center your lifter. Cheers.
Tommy
Old Jun 22, 2008 | 07:43 AM
BassCat's Avatar
BassCat
You said they also installed new headers. That tapping you're hearing couldn't possibly be an exhaust leak somewhere could it?? Just a thought.
KC
Old Jun 22, 2008 | 07:49 AM
bojangies46's Avatar
bojangies46
KC
Old Jun 23, 2008 | 03:19 PM
heng1's Avatar
heng1
yup you were right!
I just checked the headers, almost all screws were loose and one was missing !! I didn't think of checking this because I expected the shop to do the job right..
p.s. always double check, and don't rely on new parts they may be faulty too.. and service is getting worse every day. had to get that out.
Thanks guys.
Old Jun 23, 2008 | 03:55 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Just because the header bolts were loose, doesnt mean that the shop did a bad job.
Header bolts are notorious for loosening back up at least a couple of times after you installl them.
Be sure to check them again, even after you tighten them this time.
After a week or so they will stay tight.
Old Jun 23, 2008 | 04:46 PM
ghoastrider1's Avatar
ghoastrider1
NO<NO<NO<NO, you do NOT tighten untill the pushrod doesnt turn! great way to bend pushrods,burn a valve,wipe out a cam shaft! You tighten untill resistance is felt..thats it. Then you tighten 1/2 to 1 more turn....SLOWLEY,a 1/4 turn at a time. Hope ou havent bent anthing,,good luck.
Old Jun 24, 2008 | 01:08 PM
heng1's Avatar
heng1
Yea I know but it isn't the first bolt or screw that falls off or isnt tight..
Thats why they made the split screws an similar things.
I certainly will keep an eye on them
Old Jun 24, 2008 | 01:13 PM
heng1's Avatar
heng1
It is true that the literature is not very precise on this point. If you tighten very slowly at a very early point the pushrod will not turn any more, count to 5 and it does turn again, you can do this many times until it really hits the bottom. I stopped as soon as it was tight first time and then added 1 turn, I think this is a bit much. I find I had best results without the additional turn. what would be the worst? I suppose the valve just wouldn't close anymore? unless it hits the piston..? I will check this again.
To Valves problem
