Battery Charge, for Cam Break-In ?
Old Jun 23, 2008 | 02:36 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Default Battery Charge, for Cam Break-In ?
Can I start and break-in a new motor without the Alternator connected ?
Will the fully charged Battery be sufficent to run the motor for 30 minutes without the Alternator ?
Thanks.... preparing to fire up my 454 for the 69 VETT !
69VETT
Old Jun 23, 2008 | 03:21 PM
tfi racing's Avatar
tfi racing
As long as you don't drag down the battery voltage by not having your engine firing right away,you'll be fine.I would be more concerned with keeping the temp down,chances are you won't get in 30 minutes without overheating.Also be sure to roll it outside,those fumes are killers on the eyes!
Old Jun 23, 2008 | 04:31 PM
Ironcross's Avatar
Ironcross
Can you name one auto manufacturer that runs there new engines for 30 minutes of tests breaking in camshafts?
Old Jun 23, 2008 | 04:37 PM
Durango_Boy's Avatar
Durango_Boy
That's a good question but aren't most modern engines roller engines where there is virtually no cam break in?
Old Jun 23, 2008 | 05:48 PM
Ironcross's Avatar
Ironcross
Makes no difference, roller cams were not OEM parts until a few years ago on most makes except possibly some exotics.
Old Jun 23, 2008 | 11:11 PM
S489's Avatar
S489
69VETT
yes
yes - you can check the voltage as you go, if you have time; or if engine starts to miss, turn it off
good luck!
Old Jun 24, 2008 | 08:13 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Just leave charger on it while it's running.
JIM
To Battery Charge, for Cam Break-In ?
