Differential gear ratio?
Old Jun 24, 2008 | 07:34 PM
thegazman's Avatar
thegazman
Default Differential gear ratio?
I'm trying to determine the gear ratio of my differential of my 1979 coupe. I have the original window sticker, but it just lists a few of the original options; L-82 engine, electric windows and doors locks, aluminum wheels, and 255/60-15 tires, etc. Since it's not listed as an option could I assume it's a standard 3:08? I have a 350 automatic. At 3500 RPM my speedometer reads 72 MPH with 255/60-15 tires. Does this sound about right for a 3:08?
Old Jun 24, 2008 | 07:42 PM
Gordonm's Avatar
Gordonm
Sounds more like a 3.70 gear
Old Jun 24, 2008 | 07:43 PM
js292's Avatar
js292
I was to lazy to figure out your actual tire size so I guess 26" and came up with 3:08's
http://www.idavette.net/tech/ratioc.htm
Old Jun 24, 2008 | 07:45 PM
MakoShark72's Avatar
MakoShark72
http://www.700r4.com/speedoCalc/rpmcalc.shtml
Note...oops sorry, 3.55, but the website is pretty slick...figures rpm vs mph for 700r4, 2004r, and 350/400...
Old Jun 24, 2008 | 07:49 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
3.55.1 was the only rear gear that came on a 79, unless someone changed it.
Old Jun 24, 2008 | 08:18 PM
Gordonm's Avatar
Gordonm
Your tach may be off a little also. Some of the electronic tachs had a tendancy to be off a few rpm.
Just looked up in my book and in 79 as said above the standard gear for automatic 79s is a 3.55
Old Jun 24, 2008 | 11:03 PM
RIJVETTES's Avatar
RIJVETTES
Based on your info, and allowing for your tires that have a diameter of about 26.5", and using the Idaho Corvette calculations, I suspect you have 3.73 gears. Pretty steep- but explained by your high RPM's. My other info ( Corvette Chronicle by James Flammang)indicates 79 vettes came from the factory with 3.08 and 3.55 gears; and I remember one other source also indicated that 3.36 was an option that year. Unfortunately the Black Book is silent on all of this. Maybe a 79 guru out there has mo' better info to add.
Old Jun 24, 2008 | 11:52 PM
wfo76's Avatar
wfo76
I think you have the stock 3.55's and it is the extra torque converter slip of the Turbo 350
that is increasing your revs further to make them seem more like 3.70's.
The 1979 axle ratio combination info straight from GM:
L48 M20 .... 3.36 all
L48 M38 .... 3.55 all
L82 M20 .... 3.70 std, 3.36 opt
L82 M21 .... 3.70 all
L82 M38 .... 3.55 all
So all automatic Vettes in 79 had the 3.55's. The 3.36 was 4-spd only and a 3.08 was used in 78 but was N/A in 79.
Old Jun 25, 2008 | 09:34 AM
thegazman's Avatar
thegazman
Default thegazman
Thanks for all the help. My tires are 27" diameter. Using the Idaho calculator and allowing for inaccuracies in my speedometer and tach it would seem I have a 3.70 ratio. Somewhere I read that 1979 came standard with a 3.08. The low gear ratio is great around town, but nothing to brag about on a trip, 12 miles per gallon. But even at higher speeds it accelerates without any problem. One of my goals is an overdrive transmission with a lock up converter. One of the interesting things about looking at the original window sticker was the cost of the engine package. $600 was a lot money for an option back in 1979 and the most expensive option on the car. Maybe GM went with the lower gears in 1979 to maintain acceleration while reducing the HP for smog. Thanks again for your help.
Ken
Old Jun 25, 2008 | 09:50 AM
jim2527's Avatar
jim2527
Jack it up...
1. Turn wheel so valve stem is at 6 o'clock
2. Mark the driveshaft and mark the diff right next to it.
3. Turn wheel 2 or more complete revolutions.....the more turns the more accurate the results
4. count how many times driveshaft turns.
5. divide driveshaft revolutions by how many times you turned the wheel.
Old Jun 25, 2008 | 10:24 AM
KevinK's Avatar
KevinK
It's what I did, and I figured out I have 3.08s. Couldn't go by speed and RPM, cuz the fella that changed the rear end failed to adjust the speedo......when it says I'm doing 60, it's closer to about 85, lol.
Think a cop will buy that?
Old Jun 25, 2008 | 10:30 AM
ipmtim's Avatar
ipmtim
Cruise-In VIII Veteran
St. Jude Donor '06
Thats how we used to do it before this "high tech age"
Old Jun 25, 2008 | 05:22 PM
thegazman's Avatar
thegazman
Default thegazman
Originally Posted by jim2527
Jack it up...
Wow!! That makes since to me. Plus I don't have to worry about how accurate my speedometer and tach are. Funny how sometimes good common sense provides the best answer. Thanks, Ken
To Differential gear ratio?
