Need help with electrical issue: taillights
Here's the situation. Left hand brake light ONLY works when right hand turn signal is on. The right hand brake light works EXCEPT when the left hand turn signal is on. Taillights, sidemarkers, all seem normal.
My initial thought was a ground issue. I cleaned the chassis ground from the lights, and all four taillight ground studs as best I could. Checked continuity between all four grounds and chassis... everything was checked out. Problem still exists.
So I went in to borrow my wife's foot (apparently her mouth is attached to her foot, so I had to listen to her gripe as well) to operate the brake pedal while I played around with moving the bulbs in the sockets, swapping bulbs around, changing out bulbs, etc. Same problem still exists.
So I'm down to scratching my head. I did find some Bubbafied wiring on the license plate lamp, which I'm going to correct next. I don't think this is part of the issue though. Should I switch out turn signal flashers as well? I can't understand how that could be the problem, but it's cheap and easy.
Any other suggestions??
