Transmission noise, HELP
Old Jun 25, 2008 | 03:12 PM
bgall2's Avatar
bgall2
Default Transmission noise, HELP
Put my 78 on the lift on base to investigate a clicking/pecking noise underneath and it is in the transmission body. It is a clicking noise (not very loud) that gets faster with RPM and goes away as soon as auto trans shifts from first to second gear. No change in performance, however, but need to get rid of noise. Anybody had this issue or have any suggestions before I take it to a shop and have them tell me I need an overhaul. HELP.
Old Jun 25, 2008 | 08:04 PM
hugie82's Avatar
hugie82
Check the flywheel torque converter bolts. It is common for bolts to loosen and sometimes it may cause a hair line crack in the flywheel
Old Jun 26, 2008 | 11:48 AM
bgall2's Avatar
bgall2
Is this an outside job...I can look this up I am sure but do not have the expertise to open up the transmission. Thanks
Old Jun 26, 2008 | 06:47 PM
hugie82's Avatar
hugie82
Yea, it's an outside job. You will see a cover behind the oil pan with (4) 3/8 or 7/16 bolts holding it on. Take it off and you will see (3) bolts holding the torque converter to the flywheel. Take a 5/8 wrench between the oil pan and flywheel and check the bolts. If you need more access you can take the oil filter down and rotate the engine for access
Old Jun 26, 2008 | 08:18 PM
vett us all's Avatar
vett us all
I Had An Engine Knocking Noise/mains/rods. Cracked Flexplate Bolt Holes.........
Old Jun 27, 2008 | 12:21 PM
bgall2's Avatar
bgall2
Thanks...I will get it up and take a look at it very soon. Thanks for the advice.
Old Jun 30, 2008 | 10:08 AM
bgall2's Avatar
bgall2
Definitely the noise is not in the engine area. Thanks for the advice, however.
To Transmission noise, HELP
