Grease Fitting on P/S Control Valve
Old Jun 26, 2008 | 08:49 AM
Paul L's Avatar
Paul L
Default Grease Fitting on P/S Control Valve
What is the purpose of that fitting? In other words what inside is being lubricated?
Old Jun 26, 2008 | 09:13 AM
Jim Shea's Avatar
Jim Shea
There is a ball stud that connects to the pitman arm that needs grease.
Be aware, early valves (up to around 1975 or so) had a zerk fitting and a boot seal on the stud that had a small purge slit in the boot to allow excess grease to leak out.
After 1975 the zerk fitting was eliminated and the boot seal modified to eliminate the purge slit. The valve was considered to be "greased for life."
Also, now that valves are being remanufactured, it is possible to get an old valve housing (with a zerk fitting) with a newer boot seal that does not have the purge slit. (Or you could get a new seal kit with a boot seal without a purge slit to rebuild your old valve.) This combination can cause a person to attach a high pressure grease gun to the zerk fitting and completely fill the boot and cause excessive pressure to fail a hydraulic seal inside the valve. This can cause a power steering fluid leak. (That high pressure can also rupture the boot seal as well.)
Jim
Old Jun 26, 2008 | 09:38 AM
bmotojoe's Avatar
bmotojoe
My 77 has all the original power steering system still installed. May have been later then 77 as mine is there.
Old Jun 26, 2008 | 09:40 AM
Paul L's Avatar
Paul L
Thanks Jim. I have a minor fluid leak and thought it might be because of lack of grease and not because of grease being present. This car is new to me and I have no idea if a high-pressure gun was used on that fitting in the past. I have a rebuild kit and there is no grease bleed nipple on the boot seal. I will keep your words of wisdom in mind!
Old Jun 26, 2008 | 09:47 AM
FlyViper's Avatar
FlyViper
I found that out yesterday...at first it was "oh ****!", until I realized there was a purge slit. Thought I had ruptured it at first. Whew! Out of curiosity, how do you grease newer cars that don't have the grease gun nipples?
Old Jun 26, 2008 | 09:59 AM
TWINRAY's Avatar
TWINRAY
IIRC, when I put on my new replacement, it said the warranty was void if I greased it. So it appears this is one of those instances where more is not better.
Old Jun 26, 2008 | 11:22 AM
SH-60B's Avatar
SH-60B
Same here.
Old Jun 26, 2008 | 04:49 PM
Wrecked82's Avatar
Wrecked82
Jim
That is exactly what happened to me on one of my several control valve replacements. Very frustrating to have the zerk fitting, that leads you to conclude you should add grease, but not have the relief slit.
Old Jun 26, 2008 | 04:51 PM
JimT's Avatar
JimT
Be very, very, very careful if you try to grease it! You can blow the inner seal quite easily.
Old Jun 26, 2008 | 07:24 PM
Paul L's Avatar
Paul L
So I guess the best policy is DO NOT GREASE.
To Grease Fitting on P/S Control Valve
