Which Engine Would You Choose
KC.
Do a search. quite a few members here have bought them and I have not heard of any problems or issues. Has a warrenty and 400+ hp and 400+ ft lbs of torque. Best of luck on your selelction.
KC.
+1
Bang for the buck, you can't beat it.... Thats what I would go with if I was doing a basic stock motor replacement....
We have a ZZ4 in my dad's 59' and honestly, its a turd...(dynoed 255rwhp)
I just installed the year one 350, and i love it. great power. dyno sheets say 428hp and 452 tq. and all at a price that comes out cheaper than most crates around the 330-350hp range. it includes the balancer, flexplate, and intake.
Sean
Thanks again and I will post my decision soon.
Cheers.
1) Is the 700R easy to come by, relatively easy to install, and is it available in 5 or 6 speed?
2) Can you tell me the manufacturers name as well and I will get on it to see how to acquire it and recommendations for Motor/Tranny combination.
I feel inept in this area but willing to ask questions and more than willing to listen. Thanks again.
The GM crate engines are the best choise for those who can afford them and do not feel the need to experament on their own. Those engines mentioned, are all great choises but fail to mention the ultimate ones. If it's in your budget, The ZZ383 long block with Aluminum fast-burn heads is an all new, warrented engine, capable of 425 HP. I have seen these used in various applications and always with great satisfaction.
The 700R4 transmission mentioned above is a very popular automatic transmission which offers the main advantage of possiable higher gas milage. Unlike the automatic transmissions of the ers in which your car was built, the 700R4 introduced "overdrive". If you have an auto trans now (probably a TH350) the high gear has a ratial of 1 to 1. That is, for every revolution of the input shaft from the engine side, the output shaft also turns 1 revolution. In a 700R4, when in high (4th) gear, the output shaft actually turns more that one turn for every turn of the input shaft from the engine side. So, for a given engine RPM, the drive shaft is turning faster on a 700R4 equiped car and the further the car goes over a set period of time.
They are very common and produced by the millions from about 1982 until about 1992. A good source for obtaing one to handle the corvette would be "Monster Transmission" or "Eat my shift". Try www.MonsterTrans.com . They can also supply the drive shaft. I converted my 1980 L-82 to a 700R4 by simply buying the drive shaft and frame crossmember removed from a 1982 Corvette at a junk yard. The gear shift lever also has a slightly different pattern but most of this stuff is available at the aftermarket speciality houses. The 1982 vette was the first Corvette (and the only C3) to have the 700R4 from the factory.
Hope this helps!
One thing for certain is choices are nearly limitless.
My dilemma goes deeper than which engine to put in the car though, my dilemma is which car to play with and which car to sell. I will post another thread on that and ask an opinion of the forum members but supporting two 1977 Corvette's is not in the budget.
Thanks again.
David and Adam Howard
