running hot
Old Jun 27, 2008 | 10:09 PM
mbags56's Avatar
mbags56
Cruising
Default running hot
Im Running At 205 /220 Degrees I Installed An Alum Radiator 'high Output Water Pump ' New 180 Thermostat' Im Running A Solid Fan No Clutch 'installed Elect Fan Infront Of That .and Im Still Running The Same Is This Normal Temp [help
Old Jun 27, 2008 | 10:19 PM
Sayfoo's Avatar
Sayfoo
It will help if you fill in your profile so that everyone knows what year and engine your have.
The thing that helped me the most was making sure that the shroud was sealed to the radiator, to make sure that all the air goes through the radiator, not around.
Also, a few degrees of timing change can help alot.
Old Jun 28, 2008 | 12:46 AM
Retro78's Avatar
Retro78
Are you sure? Is your gauge accurate?
Old Jun 28, 2008 | 01:52 AM
vett us all's Avatar
vett us all
My 388 Takes 20 Minutes To Get To 180. Hope The Phony Global Warming Makes My Vette Use More Fuel So I Can Go Faster.
Old Jun 28, 2008 | 02:48 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
My 79 runs perfect between 205 215... so later cars designed to run a bit hotter....what year is your car?
Old Jun 28, 2008 | 03:06 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Sounds like you are running with no thermostat or it is locked in open position. Twenty minutes is way too long to reach operating temp. and this can result in sludge build up which is not good for the engine.
Old Jun 28, 2008 | 09:28 AM
mbags56's Avatar
mbags56
Cruising
Default running hot
Sorry Im New At This It's A 79 /with A New 350 Create Motor 40 Over And 10-1 Comp And The Shroud Is New
Old Jun 28, 2008 | 09:34 AM
mbags56's Avatar
mbags56
Cruising
Default Running Hot
IT'S A79 350 CREATE MOTOR 40 OVER 10=1 COMP /SHROUD IS NEW
Old Jun 28, 2008 | 10:49 AM
BarryK's Avatar
BarryK
here we go again............
lets start with the basics:
1. is it running hot at idle /slow speed driving or at highway speeds?
2. what type of "hi-flow" waterpump?
3. why no fan clutch?
4. do you have all the proper radiator and fan shroud seals installed?
5. do you have the airdam under the nose installed?
6. does the lower radiator hose have the internal spring in it?
7. what is your initial and total timing set at?
8. does your distributor have a vacuum advance and is it connected to a full manifold vacuum source and operating correctly?
9. have you checked the new t-stat to make sure it's opening fully?
Old Jun 28, 2008 | 12:23 PM
mbags56's Avatar
mbags56
Cruising
Default running hot
1- slow speed -breaking in motor 2-chrome beld drivin hi flow they told me 3-constant full air flow 4-rad yes to all 5-yes to air dam 6-no spring/ its not collasping 7-power timed at 3000 r.p.m due to cam size 8-yes to fll manifold vac 9-t- stat o.k
Old Jun 28, 2008 | 12:38 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
That's very strange.. My setup is similar to yours and my street '68 Vert runs between 170 degrees in winter and 185 - 190 degrees in summer..
I have a 170 degrees thermostat, universal Griffin radiator, ProComp water pump (35% more flow) and steel flex radiator hoses. I run a mechanical fan and a Permacool 16" electrical fan.. The hottest that the car has ever run since I upgraded the cooling system was 205 degrees and that was after sitting for 1.5 hours in stop and go traffic in close to 100 degrees heat and extreme humidity..
On the highway, I've never seen over 190 degrees..
mbags56's Avatar
mbags56
Cruising
Default running hot
1- slow speed at idle 190/195
2- chrome belt high flow they told me
3- constant full airflow
4- radiator yes it matches
5- yes to airdam
6- no spring in hose/ it's not collapsing
7- power timed at 3000 rpm due to cam
8- yes to full manifold vaccuum
9- t-stat is okay.
Old Jun 28, 2008 | 12:45 PM
ARCH's Avatar
ARCH
I run with a 160 stat on my 400. No problems. It's rare when the guage gets to 180. I have used water wetter to help keep it down, although currently without it. I do not have all my seals in place. Whenever I had a 180 in it, it always seemd to run too hot and get there fast, and take a long time to come back down. Would make me nervous.
Old Jun 28, 2008 | 12:49 PM
GrandSportC3
You are bringing up a good point.. I also run water wetter and destilled water with no antifreeze.. Antifreeze causes about 10 - 25 degrees higher coolant temps..
Old Jun 28, 2008 | 12:52 PM
GrandSportC3
another thought.. If you have a spun bearing, the oil temps and as a consequence also the coolant tems will run extremely hot.. Sometimes, it's difficult to know if you have a spun bearing... The best indication is if the oil pressure isnt consistent (bouncing up and down)
Old Jun 28, 2008 | 01:06 PM
BigEarl's Avatar
BigEarl
Double check your t-stat. I just put mine in some water on the stove and had a thermo in there. My "new" Mr gasket 160 stat didnt START to open til over 200 and didn't open fully till it was really boiling.
Old Jun 28, 2008 | 02:58 PM
ENG40's Avatar
ENG40
High flow pumps require a balanced flow thermostat...
To running hot
Old Jun 28, 2008 | 05:20 PM
mbags56's Avatar
mbags56
Cruising
Default running hot
Im Going To Try The Water Wetter & Distilled Water Is There A Balanced Ratio To Go By / Also Im Going To Change My T-stat To 160 And See What Happens Thanks
Old Jun 28, 2008 | 05:56 PM
mrvette's Avatar
mrvette
Just take the damn thing OUT entirely and see what happens...you will have a slightly longer warm up time....but so what??
so, then tell us what it does at highway speeds....40+ for a few miles in hot weather...then when you get off the freeway ramp...and set in traffic let us know what happens THEN....
BTW fixed fans are a huge energy waster, better off with electric fans....I used Dual Spals...but if you need cheeper, go to a junkyard and look for two fans off a Ford Focus, it's said they fit the install nicely...
Old Jun 28, 2008 | 06:35 PM
GrandSportC3
I use 2 bottlles of water wetter + distilled water but others only use 1 bottle
