Headlight switch ground
Old Jun 29, 2008 | 09:05 PM
Dream Bikes's Avatar
Dream Bikes
Default Headlight switch ground
Where does the headlight switch takes ground?
Directly as indicated in the pic, or inderectly from tach and speedo ground?
Old Jun 29, 2008 | 11:00 PM
...Roger...'s Avatar
...Roger...
It grounds through the metal part of the speedo housing but you have to have the lowest screw in place that sandwich the outer metal housing,the plastic housing and the inner metal housing.Of course the ground lead has to be attached to the inner housing to complete this path.
