Engine crane mods for body lift
Old Jun 30, 2008 | 01:02 PM
bonehead2's Avatar
bonehead2
Default Engine crane mods for body lift
Anyone have any info or pictures, how you did it, etc on getting more reach on your crane for a body drop?.
Old Jun 30, 2008 | 06:07 PM
hwcoop's Avatar
hwcoop
I just shortened up the lift straps...not a lot of spare lift on the crane
http://coopersgarage.piczo.com/1973c...linkvar=000044
You can also build a gantry or if you garage beams are sturdy enough you could us a block & Tackle
Old Jun 30, 2008 | 06:50 PM
bonehead2's Avatar
bonehead2
Thanks. You crane looks like it extends farther though. Did you put the body on by yourself, I have no help. Prefab trusses so I won't try that, although I thought about it. I don't know why but those straps seem shaky to me but I guess everyone uses them.
Old Jun 30, 2008 | 08:40 PM
hwcoop's Avatar
hwcoop
I had some help but you could do it yourself...just go slow and make frequent checks for things getting snagged up
They have a capacity of about 8,500lbs each so shouldn't be a problem with a 1,000lb body
Old Jun 30, 2008 | 09:35 PM
78Vette-SA's Avatar
78Vette-SA
Ditto here. I tied the lift straps into a knot at the top to shorten it way up. Were way too long otherwise.
This was from when I pulled the body on my 63 but same principle. You can do it alone, but go slow and easy. A few extra eyes would be helpful though.
Old Jun 30, 2008 | 10:25 PM
gyopp's Avatar
gyopp
I wouldn't worry about the strength of the lift straps these guys are using. I lifted mine with motorcycle tie-down straps which are not nearly as big. They are very handy because they are adjustable length. I picked mine from inside the body at the kick panel openings and behind the seat. Taking the body off by yourself is easy but I had a couple of guys I knew I could count on help me put it back.
Old Jun 30, 2008 | 11:03 PM
bonehead2's Avatar
bonehead2
Damn nice setup and car gyopp.
Old Jun 30, 2008 | 11:33 PM
GPGG70's Avatar
GPGG70
Nice Set up.
To Engine crane mods for body lift
