Going Stroking Need Some Help
Old Jun 30, 2008 | 04:40 PM
handsumrob's Avatar
handsumrob
1st Gear
Default Going Stroking Need Some Help
so i decied to take the 350 out of my 80 vette and stroke it to 383. i'v found a lot of kits and everything online that are avalible. from what i'v beening reading it doesn't seem like a completly over whelming task. i'v never rebuild an engine before or anything but i'v been rebuilding apache helicopers for 6 years now so i'm fairly confident that i can handle this. i'm just looking for any tips and advice that any of you experianced guys can give me. thanks a lot hope to hear from ya.
Old Jun 30, 2008 | 06:13 PM
rclinton's Avatar
rclinton
Veteran: Marine Corps
I'm not the expert but I just finished stroking my 80 L82. I used the "How to rebuild the small block Chevrolet" My recommendations, based on my mistakes/issues are:
1. Use ARP bolts (completely clean them prior to use)
2. I went with forged rotating assembly.
3. Check the rear main bearing oil supply hole. Mine did not line up with the bearing.
3. Use permatex #2 on all the head bolts
4. Check oil pan for clearancing prior to adding oil
5. Definitely use the one piece oil pan gasket
Old Jun 30, 2008 | 08:20 PM
Gordonm's Avatar
Gordonm
If you are stroking the 350 block you will have to clearance the block. I run a minimum of .050 clearance everywhere. You will have to mock up the crank and a rod or two fro each cylinder and measure the clearance. I took quite a bit of time doing this and removed quite a bit of material from the block. The more time spent here the better off you are. You do not want anything touching at 6000+ rpm. Also check the cam to rod clearance. depending on type and lift of cam you might need a small base circle cam. I run a big solid flat tappet and did not need a small base circle cam. Mine runs to 7000 rpm a lot and never had a problem.
To Going Stroking Need Some Help
