wiring problem
Old Jun 30, 2008 | 11:46 PM
Gumby86's Avatar
Gumby86
Default wiring problem
Just throwing out a post to see if anyone has any ideas. My passenger side lights stopped working. The headlights both work but the turn signal and the brake light does not. Only on the passenger side, which makes me think it isnt a ground issue? Any ideas? Thanks.
Old Jul 1, 2008 | 07:49 AM
Durango_Boy's Avatar
Durango_Boy
Ground or most likely a socket problem. Run a power and ground test wire from the battery so you can test the power wires to the ground wire and the ground wire to the test power wire using a multi meter. This will tell you if your socket is bad during various levels of operation.
Old Jul 1, 2008 | 10:17 AM
dannyman's Avatar
dannyman
I would check the harmonica connection at the lower end of the steering column(multiple pin socket). It is also possible that your signal switch has failed.
Old Jul 1, 2008 | 11:14 PM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
stupid question here... did you check the bulbs?
Old Jul 2, 2008 | 09:26 PM
Gumby86's Avatar
Gumby86
:P i have check the bulbs and even though they are ok, i replaced them anyway :P I cant find my multi meter , so I am gonna buy a new one tomorrow. I will let you know what i find. thanks for the replies.
To wiring problem
