76 Differential Seals
Old Jul 2, 2008 | 09:35 PM
mjdavies's Avatar
mjdavies
Cruising
Default 76 Differential Seals
I have an oil leak from the front of my differential where my drive shaft connects. I need to replace the seal. Can anyone tell me where I can get one? Am I correct in assuming this is the "pinion seal"? Many thanks.
Old Jul 2, 2008 | 09:51 PM
Scott Marzahl's Avatar
Scott Marzahl
Just about any parts store like a NAPA will have that seal. Don't forget to use sealant on the threads and flat washer under the nut to prevent leaks through the threads. Also count your threads or mark the nut so you get it back on in the same exact spot.
Old Jul 3, 2008 | 12:55 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Scott is correct, the seal is common to most parts stores. If you want instructions on how to install it here is a link.
http://willcoxcorvette.com/repairand...lp.php?hID=205
Willcox
To 76 Differential Seals
