Check Your Steering Box Lube
Old Feb 9, 2009 | 11:36 AM
  #61
Bobz08C6's Avatar
Bobz08C6
Great info. When I grab my rag joint and rotate the shaft back and forth I hear a clank clank from inside the gear box. Empty for sure. I'm going to remove a bolt today and do the straw check.
A turkey baster is a must tool for the garage and the boat. If you are having any trouble getting the mixture into the box try using a large seringe. My wife is a nurse and she brought home a few seringes that are up to 1 1/2" in diameter and 6" long. The plunger helps push harder.
Old Feb 9, 2009 | 01:10 PM
  #62
tomard's Avatar
tomard
So if I understand correctly, the car should be with wheels on the ground so that no steering movement is inadvertantly being performed.
I am going to check my box lube also, just for piece of mind!
Old Feb 9, 2009 | 01:41 PM
  #63
tomard's Avatar
tomard
Gear box has plenty of lube in there AND like Gary said, the cover is ALUMINUM By looking at mine before I cleaned it, I could have swore it was CAST IRON
BTW - what does the little tab with number on it indicate, that is sitting under LOWER bolt?
Old Feb 9, 2009 | 01:56 PM
  #64
VettePower's Avatar
VettePower
Great Tip. Never entered my mind to check it!!
Old Feb 11, 2009 | 05:25 PM
  #65
OMF's Avatar
OMF
Ttt
Old Feb 11, 2009 | 07:16 PM
  #66
OMF's Avatar
OMF
Just went out and checked mine......still full and still like grease......must have been serviced sometime in the last 32 years
