not sure which plug for sender
Old Jul 6, 2008 | 04:39 PM
madvette74's Avatar
madvette74
Default not sure which plug for sender
it's been awhile since I last attempted an installation, I cant remember which hole the oil sender goes into? is it the lower or the upper?
what would the other hole before thats not for the sender?
thanks
[IMG][/IMG]
Old Jul 6, 2008 | 05:23 PM
Durango_Boy's Avatar
Durango_Boy
The lower of the two is the factory location. The one above it might be tied into the same oil passage so you'll want to make sure it's plugged with a sealant. Edit: Yes it looks like a course thread bung, so it may be blind as well. Try probing it with an awl.
Also, ditch that Fram...they work about as good as a beer can stuffed with coffee filters. If you want cheap quality filters, get a basic WIX Filter at any Napa auto parts stores for a few bucks.
Old Jul 6, 2008 | 06:14 PM
mikep3's Avatar
mikep3
What filter do you use, I have been using Fram TG5 it seems to be longer than the TG30 suggested.
Old Jul 6, 2008 | 06:56 PM
Durango_Boy
WIX filters are one of the best low cost filters available. Napa has them, but don't spend the extra on their Gold version...it's just a higher priced filter, that's exactly the same.
Old Jul 7, 2008 | 12:17 AM
madvette74's Avatar
madvette74
Originally Posted by Durango_boy
The lower of the two is the factory location. The one above it tied into the same oil passage so you'll want to make sure it's plugged with a sealant.
are both the holes the same size? I had trouble threading the top one.. it's a it's a ph-30, I bought a wix filter and it wouldn;t clear the headers, this filter is very close to the header
Old Jul 7, 2008 | 12:50 AM
PeteZO6's Avatar
PeteZO6
The upper hole looks like it's for the clutch bell crank, or Z-bar pivot, as most folks like to call it, when a small block is used in other than Corvettes. Most non-Corvettes have the engine mounted over the front axle, and with that forward placement, the Z-bar has to be mounted further back relative to the placement in a Corvette.
Cheers,
Pete
To not sure which plug for sender
