Designing fuel system layout Q's
Some of these questions are why I avoided the electric fuel pump and went with a Race Pump piston style manual pump on my vette.
He's got a Holly Blue electric pump and provided regulator (2 outputs).
Holly duel feed 750 carb.
The diagram below is my setup idea.
Questions:
1.) Can the electric pump be mounted higher than the gas tank? and can I mount both side by side in the engine compartment away from heat? thinking about connecting pump near stock hardline in engine compartment via short braided hose.
2.) Does the inline filter only go on the push side of the electric pump? Wouldn't it be a good idea to filter the fuel before any debris flows into the electric pump?
3.) Is the fuel flow on both outputs of the regulator the same? If I put a fuel pressure gauge on one output, is that the exact fuel pressure leaving the other output? Or does the fuel pressure gauge have to be inline with the fuel being measured?
4.) What micron is recommended for an inline fuel filter?
5.) Any AN fittings that can attach a braided flex line to an original hardline? even if I had to flare the hardline.
6.) When running the electric pump, what should I connect the ignition to to prevent the pump from running if the engine was to die? Is an oil pressure relay the only option?
Your input is always appreciated. Thanks guys
Questions:
you will want the pump at the rear, it is hard to suck the gas that far. run a bigger filter behind the pump and a finer one after the pump if you like. the bigger filter so the pump does not have to work too hard to get the fuel. oil pressure switch can work there should be enough fuel in the blows to get it started then when oil pressure comes up the pump will kick in. yes there is AN lines that hook up to flared ends and then have an on the other side. regulator can be in the engine bay and with the blues and regulator that comes with them there is no need for a return line. both sides of the gerulator will have the same psi.
I wanted to avoid running new lines all the way from the tank even though I know it is recommended that the electric pump be within 3 feet of the tank. Also have to run the electrical the length of the car too. But I'll do what works, near the tank it goes.
brngrhd, got a link to that AN-to-flare fitting on Summitracing.com?
So if the Holley Blue pump does not require a return line then I can just plug the stock return line and give it a go. I'm always nervous of the risk of vapor lock when not running a return line.
http://store.summitracing.com/partde...5&autoview=sku
or somthing like this would work too
http://store.summitracing.com/egnsea...115+4294847275
the top style is how they did the brakes on the rear of my car from side to side on the nine inch. it is also how i hooked up to the stock line from the body to the rear brake hose.
Thanks for all your info!
Oh, and its an 80 Trans Am with a 400 engine
