Hello all knowing Forum, I want to replace my fuel feed from the stock pump up to the carb. Planning to buy a dual feed setup for my 670cfm Street Avenger (Holley 4150 style) and some stainless flex hose. Do I want -6AN or -8AN hose and feed line?
Currenlty running a stock ZZ4 w/ a .373 and TH350 but planning to convert to a 5-Speed.
Thanks.
I think 6AN would be fine for you. That's a 3/8" pipe. If you went up to 8AN, you'd be looking at 1/2" pipe, and isn't that bigger than the fuel inlet on the carb?
I concur.
I'm running 6 AN dual feed set up on my Holley 650.
-6 AN = 3/8 hard line.
