A/C Vacuum Supply Hose help
Old Jul 9, 2008 | 08:33 AM
Chadborne's Avatar
Chadborne
Default A/C Vacuum Supply Hose help
The solid black (no color stripe) hose running from my 1970 A/C controls has been cut and capped on the other side of the fire wall. Based on my drawings, this appears to be the vacuum supply hose. In place of it, the previous owner ran one thru (actually around) the grommet where the override switches go thru the firewall, but never connected it. My question is - Where does this supply line connect to a vacuum hose under the hood? My drawings do not show which vacuum hose it connects to.
Old Jul 9, 2008 | 08:52 AM
...Roger...'s Avatar
...Roger...
Go to the metal 3 port check valve,on the 2 port side is a small port,follow that and it should go to a T,that should be where it connects.If my memory is working!!!
Old Jul 9, 2008 | 11:27 AM
Chadborne's Avatar
Chadborne
According to the drawing I have, that small line you referenced from the check valve does run to a "T", but it consists of 1) the line to the light switch and 2) the line to the wiper door solenoid that mounts on the back of the tach. Does anyone have a pic that shows where this A/C vacuum supply line goes after it comes through the firewall on the engine side?
To A/C Vacuum Supply Hose help
