Why replace evaporator?
Old Jul 10, 2008 | 04:31 PM
shabazz18's Avatar
shabazz18
Default Why replace evaporator?
Why does the evaporator "have" to be replaced just because the system is opened? The new one isn't sealed from anything. There is no possible way to install one without exposing it to "atmosphere." HVAC conspiracy to make more money? What gives?
Old Jul 10, 2008 | 05:33 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
The evaporator does not have to be replaced unless it is leaking.
Old Jul 10, 2008 | 05:35 PM
Jud Chapin's Avatar
Jud Chapin
Thinking about this, you are probably confusing this with the dryer which should be replaced whenever the system is opened.
Old Jul 10, 2008 | 05:37 PM
shabazz18's Avatar
shabazz18
Yea thats it. The canister thingy. But Why?
Old Jul 10, 2008 | 05:46 PM
Jud Chapin's Avatar
Jud Chapin
The dryer's job is to hold any moisture that may be in the system. It can only hold so much and that is why replacement is recommended when the system is opened. Moisture is the enemy of a/c as it can freeze and block the flow of refrigerant and can also cause corrosion of aluminum parts when combined with refrigerant.
Old Jul 10, 2008 | 08:01 PM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
Exactly. Think of the drier as a sponge, when its at its capacity, it needs to be replaced.
Old Jul 10, 2008 | 08:21 PM
GPGG70's Avatar
GPGG70
Would or should a 70 vette with AC have a sight glass on the dryer?
Thanks. Thanks, Not trying to hyjack.
Old Jul 10, 2008 | 08:56 PM
Jud Chapin's Avatar
Jud Chapin
I'm fairly certain that the '70 came with the sight glass in the dryer. This aids in the charging of the system with freon. Once the sight glass is clear, the general rule is to add 1 more can of refrigerant to the system to complete the charge. It is not necessary to have this glass.
To Why replace evaporator?
