Non flip-up headlights?
Old Jul 11, 2008 | 01:58 AM
qboy's Avatar
qboy
Default Non flip-up headlights?
Does anyone make a kit that would fit on a 75?
Old Jul 11, 2008 | 07:49 AM
Pacha's Avatar
Pacha
I have convinced an aftermarket parts producer to develop a set of fixed headlights for C3.
They have two proyectors headlights per side with HID lamps on the Lows.
I don't know if they will market them but at least I will have a set
The first prototypes will we ready on august, Will post pictures.
Pacha
Old Jul 11, 2008 | 09:49 AM
Dantana's Avatar
Dantana
I bought mine with the fixed lamps already installed, not sure where they came from but I know you can buy the set up through Corvette Central, including the glass shields.
Old Jul 11, 2008 | 09:51 AM
Keris C3's Avatar
Keris C3
Default Just checking out this site!
Hi I don't have a kit but was shopping on this site and found this in my travels. Hope it helps.
http://www.tld-corvette.com/prodinfo.asp?number=591252
It would cost $279
Keri
Old Jul 11, 2008 | 04:49 PM
TPI BOY's Avatar
TPI BOY
Old Jul 11, 2008 | 06:13 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
I have some from Vanacor's I think MidAmerica and Ecklers also sells them. Not sure if this is what you are looking for.
Here is a pic of mine:
Neal
Old Jul 13, 2008 | 06:57 AM
V-Twin's Avatar
V-Twin
This is what I have. it's not completely finished yet, I still have to install an aluminium ring between the bucket and the glass to mount the lexan covers on and some mesh in the opening in the middle so you can't look back but still have ventilation to keep moisture out.
And how they come on (driving light wasn't hooked up yet)
http://video.google.nl/videoplay?doc...63854757372630
Old Jul 14, 2008 | 12:09 AM
ylose's Avatar
ylose
Pacha
Nice. That is what I intend to do. I currently have the square, recessed models in mine. I intend to put in round HID, and then the L88 style lexan covers.
Old Jul 14, 2008 | 05:27 AM
mrvette's Avatar
mrvette
The primary reason I have stayed away from any plastic lens on the front lights is the Florida sun bakes them foggy in a second...they don't last very long....some cars are so bad you can't imagine....and since a shark is almost flat to the sun in that body style, I can't see it lasting long at all.....
see site for pix....those are late camaro bulbs in the old eclker's sugar scoop setup like other have pix above....
Old Jul 14, 2008 | 06:25 PM
Pacha's Avatar
Pacha
It may be due to the plastic they use Policarbonate with UV protection should last very long but is much more expensive than pet, acrilic and most other transparent plastics.
Old Jul 14, 2008 | 06:30 PM
mrvette's Avatar
mrvette
Don't know/remember much about plastics and certainly nothing about who uses what for their cars....just know enough to stay CLEAR of the entire subject matter.....
Glass is class....it works why change the empire???
To Non flip-up headlights?
