I am about to reinstall my heater core and heater box on my 73 small block air conditioned coupe.
My question is, what did yall do to your heater box in order to seal it well? I bought the kit but im wondering if those foam seals are going to do their job. Im also wondering if I should put the strip caulk on top of all the foam seals.
If it/s a quality seal kit the foam should be fine as is. Make sure your new heater core sits in the cradle correctly as you clap it down. The crappy aftermarket one I got did not and I had to silver solder it after it broke.
I'm in the process of replacing my heater core too, and have the same concerns about the seals in the "kit" ($50+) I purchased. The distribution box-to-firewall seal is a flimsy foam that in no way replaces the original firewall insulator rubber seal. My firewall insulator was mostly missing so I'm going to make one using material I get from a heating/AC home center. Also, if your '73 is like my '69, the center divider that separates the air duct from the heater water tubes require the "tar strips". I purchased more of the "tar strips" from an auto parts store. I also used them for resealing the fan motor to case. I'd suggest comparing the old seals with the new ones and only use if the materials look similar. As you said, you only want to do this once in a life time.
I'm working on the seal kit right now for my '72 w/AC and I'm about to lose it because the directions that came with the kit are COMPLETELY USELESS. Does anyone have pictures of how they installed all their seals? I'm only working on the heater core and box. I'm not touching the box in the engine bay.
From: Graceland in a Not Correctly Restored Stingray
The original product used to seal the housing was a gray putty-like material. IIRC, last time I tackled this particular chore the dealer's parts department had it.
You can still buy the non hardening gray stuff. Go to an electrical wholesale house and ask for duct seal. Same stuff.
