Hamonic balancer Interference Fit
Old Jul 12, 2008 | 11:06 AM
mrhurk's Avatar
mrhurk
Default Hamonic balancer Interference Fit
I'm finishing up the engine build on my 73 L48. I'm using a cast SCAT crank with a balancer snout diameter of 1.236. My new GM balancer has an ID of 1.225. 11 thousandths seems like a very large interference fit to overcome when installing the balancer. Thoughts? Anybody know what the correct interference should be?
Thanks,
Dean
Old Jul 12, 2008 | 11:12 AM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
Call up the balancer tech support they should be able to give you the tolerance of how many thousandths is acceptable
Old Jul 12, 2008 | 11:16 AM
birdsmith's Avatar
birdsmith
Have you verified these dimensions by measuring them? That seems a little wierd- I'd suspect a typo somewhere. Actual interference should be closer to .001". If you actually tried to install it with that much interference you'd strip out the threads on your crank pretty quickly....
Old Jul 12, 2008 | 11:38 AM
mrhurk's Avatar
mrhurk
I've measured both with a digital vernier caliper. Readings were consistent when taken at 120 degree intervals around the circumference of both pieces. i did find something interesting. on about ther first 3/8 inch of the balancer (engine side) it has been machined to about 1.235. This part slides on to the crank with a little effort.
Old Jul 12, 2008 | 11:53 AM
stock76's Avatar
stock76
They may tell you that you will have to hone the balancer a bit to enlarge the ID in order to install it. I installed an ATI Super Damper balancer on my stock l-48 crank snout and had to hone the damper slightly to open the ID up, and then use anti-seize as the lubricant on the crank snout, to install the balancer. The tolerances were in the installation instructions.
The specs will most probably be different for your combination than mine were, but you may need to do a little machining in order to install your balancer.
Old Jul 12, 2008 | 11:56 AM
jetnoise's Avatar
jetnoise
I purchased a stone brake hone from advance auto, attached it to my cordless drill with some oil. Took basically just the paint off the balancer and went on smoothly.
Old Jul 12, 2008 | 07:13 PM
vett us all's Avatar
vett us all
Old Jul 12, 2008 | 07:54 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I doubt you will get satisfactory ( accurate ) results with calipers, that is not the way to measure these components. Does the balancer go on with some resistance like it is supposed too ?
Old Jul 12, 2008 | 08:24 PM
C3 Stroker's Avatar
C3 Stroker
The interference fit should be closer to .005 or slightly less. If it starts to go on (tightly) but you're starting to get nervous, I've had success by removing it and heating it in hot (but not boiling) water, then quickly out of the water, apply some oil then install it. It will go on easier.
To Hamonic balancer Interference Fit
