My Vortec Combo disappoints
Old Jan 18, 2013 | 03:26 PM
  #221
Little Mouse's Avatar
Little Mouse
Originally Posted by 63mako
Have a 1978 Mercedes Unimog. 40 HP deisel engine, 20 forward gears, 14.5 x 20, 42" tall tractor lug type tires, 4 wheel drive. top speed 55 MPH. It isn't fast but it will pull anything. Gearing makes that 40 HP seem like 300+ when you hook it up to something.
Thats cool i saw one of them on pawn stars.
Old Jan 18, 2013 | 04:41 PM
  #222
REELAV8R's Avatar
REELAV8R
1938 Chevy "one ton" truck from the forest service. Six cylinder inline splash lubrication system, displacement unknown. It could climb a tree in first and at the piston swapping rpm of 3500 in fourth gear did 45 mph.
That one ton could haul about 4 tons without a problem.
Old Jan 18, 2013 | 04:55 PM
  #223
Solid LT1's Avatar
Solid LT1
You compression ratio is fine! You might want to look at a Comp or Lunati Voodoo cam in the low 220 degree range. I think your restricting your motors potential with the short duration cam especially with a 4 speed manual transmission as performnce under 2500RPM shouldn't be too much of a concern with a manual transmission unless your doing off road 4X4 trails. Your beehives should allow around 0.500 lift but, this should be measured and not assumed. I would pick something like this cam: http://www.lunatipower.com/Product.aspx?id=2325&gid=297
Old Jan 18, 2013 | 05:57 PM
  #224
SuperBuickGuy's Avatar
SuperBuickGuy
Sounds like all of the straight-6 powered FJ40s I've ever owned (7 and counting).... their problem was the same, not enough gear. Climbing Mt. Rose (near Reno) was painful as 2nd was at redline and 3rd was too steep.... this with 5.38 gears in either end... wasn't fast, but it'd climb anything that it could get traction on sssslllllooooowwwwlllllyyyyyy. I think I celebrated two birthdays in one climb of Mt. Rose.
Old Jan 18, 2013 | 06:32 PM
  #225
63mako's Avatar
63mako
St. Jude Donor '08-'09
I like that cam but the rear gear will still hold it back.
Old Jan 19, 2013 | 06:10 AM
  #226
Matt Gruber's Avatar
Matt Gruber
The OP did confess he now doesn't go on the highway.
3.70 or 4.10 is fine around town. It is fun to shift into 2nd WOT and not be speeding! And in my 61, 4.11, i get 15-18 mpg if i go with the traffic flow. Single pattern cams don't send as much fuel out the exhaust. That mpg info isn't in the fine print on those voodoo etc cams with long, loud, exhaust duration.
As far as NOISE, i'm not deaf like mako so i use earplugs.
Old Jan 19, 2013 | 06:56 AM
  #227
cv67's Avatar
cv67
St. Jude Donor '05
Sure?
Old Jan 19, 2013 | 07:36 AM
  #228
Matt Gruber
More overlap lowers mpg. Sure one could design a cam intended to minimize the effect, but that is not the intent of the newer off the shelf cams. Customers want power, noise(race car sound), lumpy idle, not mpg. At least it is NOT on their list at the time of purchase. After a few fill ups
Old Jan 19, 2013 | 01:38 PM
  #229
63mako's Avatar
63mako
Depends on your parameters. Single pattern cams are fine if your intake/exhaust flow ratios are high 75-80% and up. That said the design of the 23 degree head does not usually allow that. Factor in exhaust restriction and a dual pattern will increase hp over a single pattern in most intances. If you have AFR heads (high I/E ratio) and big headers with very low restriction exhaust a single pattern will be ok.
Old Jan 19, 2013 | 02:46 PM
  #230
Matt Gruber
There are often exceptions, but even the un-exciting SR Torquers didn't need more exhaust duration in that dyno test i often quote. The frequently claimed benefit to more exhaust is, it extends the rpm range. But, how often do we see guys wanting more rpm? For the 270H, comp says max hp at 5800, shift at 6000. Jeff shifts it 6900 wth vortec heads, i've been to 7000 a few times. So how much more is needed, and for what purpose? And your warnings about too much CR, wouldn't less efficient removal of exhaust help tame detonation? Could this be what maxes out your CR at a lower CR then others? Carl Hinkson(engine shop) uses single pattern cams with higher CR STREET engines.
Old Jan 19, 2013 | 03:10 PM
  #231
Priya's Avatar
Priya
Matt, I wasn't able to send you a personal message so I'll ask for your cam recommendation here. I'm planing on building a Vortec headed 350 with the Scoggin Dickey base plate for Tuned Port Injection. The goal is to maximize gas mileage at the 325-350 gross flywheel hp level. Scoggin Dickey says Vortec heads and their Vortec baseplate on an otherwise stock L98 produces 305 hp. That's with 207/213 duration and .415/.430 lift cam
Scoggin Dickey says they made 357 hp @4900 rpm by adding an LT4 Hot Cam, 1.6 ratio rockers (.525/.525 lift 218/228 duration) a 52mm throttle body, and Edelbrock High Flow runners. That seems like an awful lot more cam for the extra 50 hp and it would have a significantly negative effect on gas mileage.
I don't want to change anything else in the TPI other than cam. The stock L98 cam seems pretty mild. I know the stock L98 peak power is at around 4500 rpm and runs out of steam at about 5000. I want my motor to pull to the 6000 rpm redline where I'll shift. Low speed torque is not particularly a concern but gas mileage is. Any thoughts on what would be a good cam for this combo that would produce 325 gross hp or better yet still get good gas mileage?
  #232
cv67's Avatar
cv67
St. Jude Donor '05
Running a cam up that high is a complete waste all its doing is creating heat. 270 is a little cam
Old Jan 19, 2013 | 03:31 PM
  #233
Matt Gruber
Priya
roller cam or FT, solids ok? or just H?
I'm not any sort of cam designer, so others with similar builds should be given serious consideration. Hopefully they will chime in.
Old Jan 19, 2013 | 03:43 PM
  #234
Priya's Avatar
Priya
Priya
Hydraulic only.
Old Jan 19, 2013 | 03:55 PM
  #235
Little Mouse
Originally Posted by Priya
You've both overlooked my experience with the 3.70 rear and the factory 4 speed and its 2.54 first gear:
So, you're suggesting I start out in the 5 speed's even lower 1.99 second. I'm pretty sure that's a bad idea given how the car reacted with the m21's 2.54 first. No, my 3.70 reared car needs a much lower gear than the factory 2.54. I'm hoping with the 3.37 first in the five speed there will be some wheel spin but I'd bet it won't be excessive with the present 295/50 15 rear tires.
Remember I'm planning on building a similar motor to the OP's and he's complaining about the off the line slow acceleration. I had a 70 Torino with 3.89 rear gears and 22 inch tall tires which is the equivalent of a 4.95 rear gear with 28 inch tall tires such as on the Corvette. With the Torino's 2.78 first that was an overal first gear ratio of 13.76. Did it spin excessively? Yes, but not so much so that it didn't love driving it or was ever tempted to start out in second. It had a 6000 rpm 351 cleveland which didn't produce much power below 2500 rpm but came on real strong at higher rpms. I'm looking to duplicate that motor's performance with my 350.
In the Corvette with its 2.54 first I find I'm revving the motor a lot faster than I'd like and riding the clutch to get it moving from a stop and I find it really annoying to initially get it moving - it needs a lot more gear for my taste. And with the 3.70 gears in my Corvette I'm revving at about 3000 rpm at 60MPH - also very annoying. The .67 5th gear in the Keisler trans brings this down to 2000 rpm, a lot better for crusing and a lot better for gas mileage.
So, no offense guys, but I'm going with my opinion on the five speed, not yours and I think its ideal for my heavy corvette with the planned low torque 325 -350 gross hp 350.
3.89 X 2.78 = 10.81
3.37 with a 3.70 will be some overkill its going to feel like a granny geared 4 speed pickup truck in low gear. You should like the overdrive part of it.
3.37 x 3.70 = 12.46, 5.57 rear x M21 muncie 2.20 = 12.25
Welcome to the world of 31 inch dia. slicks and 9,000 plus rpm.
BFgoodrich 295/50 , 26.65 Dia.
I drove two cars with 26 1/2 dia. street tires bolted on one 4.88 other 5.13, 1rst gear in either one was unusable quickly shift it to second. You should have something simular to about 5.70 rear gears in low. Spinning tires in low will be no problem lol.
Old Jan 19, 2013 | 04:08 PM
  #236
Matt Gruber
Priya
TPI to 6000? You are dreaming
Talk to the c4 guys! I don't have a clue offhand. Sorry.
Oh wait, there was a c4 guy years ago that put afr heads on a TPI and it was quite a surprise how well it ran w/cam and mods.
That TPI will get good mpg. That is all i know about TPI
Old Jan 19, 2013 | 04:12 PM
  #237
Priya's Avatar
Priya
I've looked at a number of C4 TPI builds and many of them are running to 6000 or more but all the one's I've looked at are like 400 hp or more and they're running mid to low twelve second quarter miles with their C4's. I haven't found any C4 tpi builds that are of a moderate performance such as I'm after.
To My Vortec Combo disappoints
Old Jan 19, 2013 | 10:33 PM
  #238
63mako's Avatar
63mako
Another reason the OP has a doggy ride. It came with a 3.70 4 speed likly a close ratio trans 2.43 1st. that and a 3.36 rear is 8.16 first gear. To get to the optimal 10 to 1 first you need a 4.11. Then highway cruise sucks.
Old Jan 19, 2013 | 11:06 PM
  #239
cv67's Avatar
cv67
St. Jude Donor '05
Gonna be hard to get a TPI to pull up that high its the runner length that handicaps it. Will it rev up that high maybe making power there no.
Shoot for something in the low to mid teens most at .050 thats how they run best, gear and converter accordingly.
LT4 cam was meant for a stick with low gears, short runner intake.
Guys use them on the TPI with some success they are not bad just better choices out there.
Old Jan 19, 2013 | 11:33 PM
  #240
Little Mouse
Yep i did not know he changed the 3.70 to 3.36 until he finally mentioned it.
LS4 is not much for a 454 but it still had buckets more torque down low then this lightly modded 350 will ever see. 2.20 low gear with a 3.36 is no drag machine even for a 454 lol.
No wonder why he is dissapointed.
