Chart for Numbers Matching Motor
Old Jul 12, 2008 | 01:29 PM
Kahle76's Avatar
Kahle76
Default Chart for Numbers Matching Motor
I'm trying to find out if my motor is the origional. Can anyone tell me where I can find any info(books, links ect.) or better yet can you just tell me?
My VIN is 1Z37X6S435136
Car is a 76 L82
I think the motor is stamped V0426CKC ?? Hard to read. Can you also tell if this is a 4-bolt main?
Thanks Guys!
Old Jul 12, 2008 | 01:42 PM
ROBRICCI's Avatar
ROBRICCI
your motor is probably original if it has your vin number stamped next to the numbers you gave us....to tell if its the right block...look behind the distributor down by where the transmission bolts to the block and you will see some casting numbers that will tell you the actual block and the casting date....it may be grimy but i assure you...they are there....
good luck
RR
Old Jul 12, 2008 | 01:43 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Just below the front of the right hand head there is an area of the block protruding that should show the #'s you are looking for. Part of the # should be the last 6 digits of the VIN, 435136 in your case, which would indicate your car has the original engine.
Old Jul 12, 2008 | 02:03 PM
Kahle76's Avatar
Kahle76
Thanks guys! I did see another smaller set of numbers and I will put the glasses own and see if they match.
Old Jul 12, 2008 | 03:43 PM
Kahle76's Avatar
Kahle76
It is the origional block! Where can I find out additional info about the trans. , heads ect. with out bothering you guys? Thanks again!
Old Jul 12, 2008 | 03:45 PM
Jud Chapin's Avatar
Jud Chapin
Glad the block checked out!
Old Jul 12, 2008 | 03:52 PM
nutsy's Avatar
nutsy
to check the heads i beleive you have to take the valve covers off.
Old Jul 12, 2008 | 08:14 PM
wolfemc's Avatar
wolfemc
Default Easy way to see head number
On my '70, the d/s head casting number is just below the oil filler cap in the valve cover. Take off the cap and use a flashlight. If one's correct it's likely that the other is also
Old Jul 12, 2008 | 11:04 PM
Kahle76's Avatar
Kahle76
Thanks again.
Old Jul 12, 2008 | 11:34 PM
Jud Chapin's Avatar
Jud Chapin
You're welcome.
To Chart for Numbers Matching Motor
