heater core shutoff 69
Old Jul 13, 2008 | 03:05 AM
Kenneth W Dantley Jr's Avatar
Default heater core shutoff 69
I'm installing a heater core shut off and my hose that returns from the heater core passes throw the coolant overflow. Is it OK to shut off this type system. Also the shutoff valve I bought narrows considerably from 5\8 to maybe 1\4 is this ok. I'm assuming that its fine but I thought I double check before I did it.
Old Jul 13, 2008 | 10:18 AM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
I sure would like to see a picture of that!
I don't claim to be anything special on cars, but a heater hose running through the overflow seems a little weird.
Putting a 5/8 to a 1/4 valve will be a problem. 1st..how are you going to connect the hose to a 1/4 nipple. 2nd... as long as you have the valve shut off it won't make a difference. When you open it you will have a problem. Too much restriction. I assume that the heater hoses are that size for a reason. I think it would be a lot easier to just go get another valve.
Larry
Old Jul 13, 2008 | 10:22 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Yes, that doesn't make sense in light of the pressure of the cooling system.
Old Jul 13, 2008 | 10:43 AM
...Roger...'s Avatar
...Roger...
The heater hose goes in and back out of the coolant tank with a 1/4 or 5/16 back to the rad. tube.Here is a link showing the tank he is using.(There are 3 nipples on the tank one of the larger ones you cant see very well plus one for the overflow)
http://www.volvette.com/CL018.html
Old Jul 13, 2008 | 10:53 AM
lebvette's Avatar
lebvette
Would someone explain how it works, and why it is like that.
My overflow is a plastic tank.....live and learn.
Larry
Old Jul 13, 2008 | 11:00 AM
Paul L's Avatar
Paul L
There's a difference between a coolant tank and an overflow tank. My 1967 does not have a rad cap on the radiator. The system is pressurized through a cap on the coolant tank.
To answer the question, this valve from Home Depot works.
Old Jul 13, 2008 | 03:30 PM
A different view of the Expansion Tank
http://www.zip-products.com/Zip/prod...sp?pf_id=M-319
My hose is not T like Paul’s. Just in one side out the other. I don’t know if that makes any difference.
My shut off looks about the same as Paul’s 5/8 to 5/8 but inside of the valve its pretty small. But I suppose if it’s not as hot as it’s could be it’s probably not a problem.
Old Jul 13, 2008 | 03:56 PM
...Roger...
You probably dont need much heater action in Texas anyway. Most valves are going to downsize some. If your worried about the flow you can always do what I do and thats just put a clamp on the 5/8 hose-no valve to buy-no extra clamps to leak-just remove clamp and you have full flow once again-great for NCRS because the valve is not there-best of both worlds.
Old Jul 13, 2008 | 11:43 PM
Yep, most of the year the last thing you want is heat.
Lower flow doesn’t matter to me as long as it doesn’t mess any thing up.
Old Jul 14, 2008 | 09:53 AM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I have a 69 350/350 with the same issue - How to install a shut off. Now please correct me if I am wrong here but:
There is no radiator cap on the radiator making this external tank the expansion tank for the radiator. To me, that means that you must keep the flow of water to & from the expansion tank. If you restrict the flow on either hose, you will be increasing the pressure within the radiator, which creates a different problem.
My solution was to by pass the heater core - going from the water pump to one port on the expansion tank, the from the expansion tank back to the block.
I don't drive in the winter anyway.
To heater core shutoff 69
