aluminum valve spring retainer
Old Jul 13, 2008 | 01:46 PM
Little Mouse's Avatar
Little Mouse
Default aluminum valve spring retainer
Anyone know where I can find the aluminum valve spring retainer #330586 that fits valve spring 330585. I can't seem to find any aluminum valve spring retainers.
Thanks for any help
Old Jul 13, 2008 | 04:00 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
You going to use this on a street motor??
Old Jul 13, 2008 | 04:17 PM
Thmprr's Avatar
Thmprr
The reason why you can't find them anymore is because they were a bad product that failed within days, sending aluminum shavings into the engine oil.
Old Jul 13, 2008 | 06:35 PM
Little Mouse
I'm just joking no way on the planet I would use an aluminum retainer
even when I was younger when chevy sold them over the counter.
Those two part numbers are legitimate chevy part numbers from the fith edition Chevy power parts book. Chevy out to be shot for putting out junk like this for sale.
Old Jul 13, 2008 | 07:34 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
I ordered mine from www.sdpc2000.com I guess its www.sdparts.com now.
Old Jul 13, 2008 | 09:25 PM
gkull's Avatar
gkull
I've worn out titanium retainers in just a couple of years. I was wondering if aluminum might last on some low spring weight h-flat cam or something.
Old Jul 14, 2008 | 02:48 AM
Little Mouse
Ok looked it up for you #330586 aluminum retainer was to be used
with 330585 spring with chevy racing cams # 3927140 or # 3965754.
#330585, spring height 1.72, 135 pounds seat, 290 pounds at .500 lift.
#3927140 mechanical first design, .050 duration 243/254,
valve lift 481/486.
#3965754 mechanical second design,.050 duration 249/258,
valve lift 503/508.
To aluminum valve spring retainer
