polished water pump
Old Jul 13, 2008 | 05:50 PM
ron69's Avatar
ron69
Default polished water pump
I'm trying to find a chrome or polished water pump for my
'69 350-300hp small block. Is there a direct replacement?
Thanks, Ron
Old Jul 13, 2008 | 08:28 PM
marshrat99's Avatar
marshrat99
Try Mid America Designs (MAD).
Old Jul 13, 2008 | 08:38 PM
ron69's Avatar
ron69
I checked them out. The chrome or polished one is for 71 and up. The 69 is black or stock AC Delco. I'm calling Jegs and Summit tomorrow to see if the Edelbrock endurashine is available for my engine.
Thanks, Ron
Old Jul 13, 2008 | 09:14 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
E-Bay has a few....
http://cgi.ebay.ca/SBC-CHEVY-SHORT-W...QQcmdZViewItem
Old Jul 14, 2008 | 02:19 AM
gingerbreadman1977's Avatar
gingerbreadman1977
i didnt like the limited options for corvette polished parts with pulleys and things so i bought a normal 350 water pump with standard 350 polished w/p pulley and crank pulley from summit. much easier with the standard sized w/p shaft and alot cheaper.
Old Jul 16, 2008 | 12:17 AM
oldboat's Avatar
oldboat
Default stewartt water pump
i run a stewart water pump in my '69 350. they have several different levels of water pumps. i just use the standard one. it looks good and flows much more than the stock pumps.
http://www.stewartcomponents.com/
Old Jul 16, 2008 | 04:59 PM
68/70Vette's Avatar
68/70Vette
Thanks, Ron
I'd go with an Edelbrock Endurashine polished aluminum pump. A chrome plated cast iron pump will eventually (or soon) start to show signs of rust.
Old Jul 16, 2008 | 10:02 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
check with durangoboy, last I knew he still had his for sale.
To polished water pump
