Distributer - How loose should it be...
Old Jul 13, 2008 | 11:20 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Distributer - How loose should it be...
Pull the distributer today just to get a better #1 alignment. I noticed that the shaft the mounts the weights is loose and moves around 10 or so degrees once installed. Is this normal. The whole rotor moves to easy for my liking. Also, should the weight springs be tight or loose?
It would be nice to have on of those old snap on dizzy machines.
Old Jul 14, 2008 | 05:36 AM
Matt Gruber's Avatar
Matt Gruber
good job,
u found a problem there
typical shot springs
Old Jul 14, 2008 | 07:22 AM
MN80Vette's Avatar
MN80Vette
Have you checked the play in your distributor gear? Ideally it's supposed to be a few thousandths. Mine had about 3/16" play!! As the distributor gear bounced up and down, the timing would vary a lot. I installed distributor gear shims and the roughness and variabiability went away. Also make sure your weights move freely. I polished the contact surfaces on mine.
Old Jul 14, 2008 | 09:11 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
I'll pull it tonight and check to see what I need to order.
To Distributer - How loose should it be...
