72 sb engine compartment heat
first thing I would do is get rid of the heat riser below that exhaust mani on the pass side.....block it open, make sure it stays open...better off toe remove entirely and weld the pivot openings.....if you have a mind to, you need pull the intake and plug the heat riser crossover passage under the carb, I have used Plaster of Paris for years for that work, and have some now in my Mani on my car.....totally flameproof, and stops the heat....
carb and mani, and everything on top runs LOTS COOLER>...
now this maybe not the best for way northern wintertime operations, but if you in mild climates, it's fine....you will want to change over to electric choke also, as the old air tube in the crossover will be totally disabled with the plaster trick.....
I think you also want to be damn sure of the overall engine temps....put in a mechanical gauge, and obviously make sure the radiator is in GREAT shape....
see the lower hose don't collapse under higher engine speeds, killing flow....
make sure your thermostat opens properly and don't act funny....I preferr MURRAY brand to Stant....I have had nothing but bad luck with Stant....IMO they are junk....
I would pull it off and do the Plaster/Paris trick, it's the ONLY solution that actually works....the blocker plates in some gaskets blow out with fire.....
I know this the hard way....don't ask....
