e3 plugs
Old Jul 18, 2008 | 10:34 AM
minxdog's Avatar
minxdog
Default e3 plugs
I'm getting ready to put new plugs in my 79 vette and I am thinking about using e3's.
Has anyone had any experience with these plugs good or bad?
thanks
Old Jul 18, 2008 | 11:29 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
IMHO, don't waste your money.
Old Jul 18, 2008 | 04:46 PM
baxsom's Avatar
baxsom
I just did a quick google on them and it seems that the only time anything good came up was on the sites that were selling them.
Old Jul 18, 2008 | 05:46 PM
stingr69's Avatar
stingr69
Not even worth the wrench time even if they were FREE.
JMO.
-Mark.
Old Jul 18, 2008 | 06:04 PM
minxdog's Avatar
minxdog
well unfortunately i got the plugs before i got back on here, but before putting them in i held them up against the plugs that were in the motor and it looked as if the part that is inside the motor when the threads bottom out is noticeably longer then the plugs that came out. Should that concern me?
Old Jul 18, 2008 | 06:52 PM
Highhat's Avatar
Highhat
It could be a concern. Your heads call for a plug with a certain plug length. Too long and your piston could hit it, especially if it is a flat top or domed piston.
Old Jul 18, 2008 | 07:01 PM
thegazman's Avatar
thegazman
Default thegazman
I had E3's in my 1979 L-82. They fouled so easy and created a miss I removed them and threw them away. I switched to Accel's. Haven't had a problem since.
Old Jul 18, 2008 | 08:48 PM
rponfick's Avatar
rponfick
A lot of people will tell you to stay with what came in the car. That would be AC's. OEM, OEM, OEM, seems to have a ring to it.
Ralph.
Old Jul 18, 2008 | 11:34 PM
Jud Chapin's Avatar
Jud Chapin
Ralph.
Old Jul 19, 2008 | 06:58 AM
mailbox1024's Avatar
mailbox1024
Well how did it work in your car? Have you installed them yet with any positive or negative results? Let me know.
thanks...
Old Jul 19, 2008 | 09:10 AM
thegazman's Avatar
thegazman
Default thegazman
When you install the E3's make sure you vehicle is running a lean as possible safely. Running just a little on the rich side will cause the electrodes on the E3's to foul due to their design.
Old Jul 19, 2008 | 10:07 AM
vett us all's Avatar
vett us all
Default Plugs
thanks
E3S C3S I USE DENSO IRIDUIMS. TRIED AC PLATINUM, DENSO'S ARE PRICEY THOUGH. $14 A PLUG
Old Jul 19, 2008 | 09:52 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
I bought a set and had them installed....at first, I notice a small "seat of the pants" increase in performance. BUT after driving for about 3 months, I noticed the engine started to miss at idle... I pulled the plugs to check them out and the electrode didn't look like any other spark plug electrode I've ever seen. The best I can describe it is...sort of "rust" looking. The insulator looked fine (light tan)...the threads looked fine (no oil).
Didn't feel comfortable with that, so I went back to NGK plugs and haven't looked back...should have never changed them...but nothing ventured nothing gained.
By the way, the miss at idle....gone!
Hope this helps...good luck!
To e3 plugs
