Few vortec head swap questions
1) Use the same rockers and push rods?
2) My Q-Jet has an exhaust heated choke, The vortec heads do not have that provision, can I convert my carb? if yes how
3) Are accessory holes the same?
Any other tips would be appreciated.
Thanks guys. Lee
Thanks guys. Lee
1) Yes, so long as the rockers are either self aligning, or if you have guide plates. However, if you don't have self aligning rockers, you will need guide plates and that requires hardened push rods.
2) I understand that there is an electric choke kit available...maybe PM Lars for more info on that kit.
3) Yes, the accessory holes are the same...even size.
You'll want a set of Fel-Pro 1255 gaskets. They are good and thick and have dual bolt patterns. You can order them through most local auto parts stores. Use a 3/8" thick bead of high temp silicon for the end seals.
Depending on your year, you'll probably have some issues with a temp sender. The holes in the Vortec heads are smaller than your stock sender so to make your stock sender work you'll need to drill and tap the hole for the larger design. You can't just buy a later model sender because the resistance is different and you won't get an accurate reading.
The Vortec head swap will give you the best results if you pair it with a cam and lifter swap too, and it's also a good time to replace the timing set and replace the oil pan gasket with a new Fel-Pro one piece design.
Finally, if you go ahead with the timing cover and oil pan you might as well change the rear main seal to get you extra time in case your stock rear main seal gives out.
Are the rockers that come with the vortec heads self aligning or do I need to go after market?
Lee
Thanks guys. Lee
